so i found out what amplifier IC is inside the stock deck
it's a Toshiba TA8264AH
http://www.semicon.toshiba.co.jp/eng...poweramps.html
it's interesting how the TA8273H is found in decks which people would consider better than stock yet it uses an amplifier that is very similar to the TA8264AH.
TA8273H = 25w *4 channel @ 13.2V and 10%THD (47watts max. per ch)
TA8264AH = 21w *4 channel @ 13.2V and 10%THD (41watts max. per ch)
THE DECKS FOUND IN THIS LINK ALL USE THE TA8273H
http://carradio.al.ru/?i=bn&searchname=ta8273h
so what actually makes the aftermarket decks better than the stock one? the preamp?
also, since i can trace the line input into the amplifier IC, can i just tack on some wires and use the stock amp's input signal as a pre-out for an amp? will i have any problems if i do this? eg. will i gut a loud pop on the amp everytime i turn the car on?
oh yea,
forgot to mention THD....
0.02% THD @ 5watts and vcc of 13.2V
Toshiba Datasheets really suck..that's all they'll list. it doesnt list how much power it'll output at 1% THD
anyways, it sounds as though a lot of aftermarket decks suck...heh..
IMO, these toshiba IC's are crap
Re: so i found out what amplifier IC is inside the stock deck
i boogie for the raindrops
so therefore, my theories are proven... if its 21 rms at 10% thd (completely unlistenable), and its a linear scale (doubtful), then at 7 watts, output will have a thd of 1.3%, which is totally unacceptable in anything above 150-200 Hz
Re: Re: so i found out what amplifier IC is inside the stock deck
Originally posted by opto_isolator
Its numerous things - including the design of the circuit. The amplifier is just one part of the who shebang. If the other parts that they used suck @ss than its not going to help (caps, inductors, resistors, etc). Don't forget the power supply. If its not clean, you're going to get some noise as well....
also, the powersupply is limited by the car battery's supply voltage. decks dont use the switching power supplies found in amps because there's no space for it.
as for caps and resistors, the stock deck uses respectable name brand parts. eg. capacitors are made by "nichicon" which is better than those bulging caps found in motherboards :P
the toshiba amp chip requires very very few external components so lack of external components is not really an issue.
btw, the preamp chip inside the stock deck is a Philips TAA7704H. i'm sure it's not a very good preamp but i wasnt able to find the datasheet for it
anyways, what i'm saying is it seems that all cheaper decks use crap parts. it seems the only advantage of those decks are stuff such as a flashy faceplate, preouts, and mp3 playback. from judging by the parts found in those lower budget decks, sound quality wont be much of an improvement over the stock deck. it's not until you spend $400+ on a deck that you might get some quality components inside.
ok i found the THD vs Pout graph
it shows 10khz, 100hz, and 1khz are all under 1% THD until it reaches around 15watts. that's when THD begins to skyrocket to 10% at a very steep slope
Vcc =13.2V
RL = 4ohm
Re: Re: Re: so i found out what amplifier IC is inside the stock deck
Other parts suck ***? it's possible but there arent very many parts inside a head unit. decks use highly integrated IC's and there isnt much circuit designing to do. the parts manufacturer gives them a reference schematic and that's what they'll use. the toshiba amp chips suck but then if kenwood and jvc are using the same chips in their $300 decks, then isnt it likely that they cheaped out on the preamp too?
Vcc =13.2V
RL = 4ohm
Vcc =13.2V
RL = 4ohm
even if you dont count that,
anything even NEAR 1% thd is still sucky. i dunno if youve ever heard 1 khz at 1% thd, but you can definitely hear second and third order harmonics in it
i bet the chip for whatever equalization the stock deck has is a piece of ****.
Re: Re: Re: Re: so i found out what amplifier IC is inside the stock deck
Yes, the manufacturer does give a "reference" design, however about 99% of the time the designer doesn't follow it. Most of the spec sheets you see are for amateurs. I can guarentee you that almost all of the manufactures don't follow that crap. Designing an amplifier is not a walk in the park my friend. Spending 5 years at an engineering school, I can tell you that there are a lot of things to consider - and yes, regardless if there is a lot of parts or not, they all still must be of good quality. All parts have a tolerance, be it 1%, 5% or 10%. Most manufacturers choose to use 10% tolerance parts because in the long run it can save them a lot of money. And again, the power supply matters. It doesn't matter if it is a switching power supply or not - noise can and will still get in. If they don't filter the power as well, your amp and preamp are going to suck *** - I guarentee it.
clarion makes some average amps, arc audio makes some beautiful amps.
about a year or two ago, you could open arc audio and clarion amps and the board schem looked almost identical, but with different heatsinks.
what happened was, arc and clarion both had the same OEM, but arc was obviously paying more money for the amps, because the clarions used all 5-10% tolerance parts, and the arc audio's are pretty much all 1% tolerance parts.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Youshoe
May 22, 2015 09:36 PM
Supramk3
May 11, 2015 07:55 PM
ej8
Apr 13, 2015 06:36 PM
