Hand me down subwoofer????????
Old Apr 27, 2004
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
Hey guys maybe you can help me out, well i was planning to purchase a brand new subwoofer when my uncle informed me that he had a Subwoofer sitting around the house and that he wouldnt mind if i used it. The sub is a Kenwood (KSC WA 100) now i dont know anything about this sub to me it looks kinda old i just wanted to know once i installed it would it give me just enough kick??????? also guys i needed to know which size AMP would i need to push the most out of the sub thanks alot.
Old Apr 27, 2004
PunkingCivic's Avatar
I need TP for my bunghole
http://www.kenwoodusa.com/product/pr...&productId=148
GENERAL FEATURES
- Adjustable Analog Input Sensitivity
- Dual 2-Ohm Voice Coils
- Maximum Output Power: 100 Watts (50 Watts + 50 Watts)
- Mounting Belts Included for Easy Installation
- Parallel RCA Inputs/Outputs: Gold-Plated
- Phase Switch
- Ported Enclosure
- Power Indicator: Triangle in Logo
- Powered 10" Subwoofer
- Variable Low-Pass Electronic Crossover: 80Hz - 300Hz
POWER RATINGS
- Rated Output Power: 60 Watts (30 Watts + 30 Watts)
AUDIO FEATURES
- Speaker Level Input Terminals
SPEAKER FEATURES
- Ported Enclosure
- Woofer: 10" Pearl Mica Injection-Molded Polypropylene Cone
Old Apr 27, 2004
It shouldn't need and amp it is already powered.
Old Apr 27, 2004
Novaz3's Avatar
so how good do you think it will sound inside my car?????? i mean do you think that its a decent sub??? or will it sound no better then my reg speakers ?????? what wires should i use to get the best sound from the sub??? MONSTER CABLES????? or what
Old Apr 27, 2004
Its not gonna make your heart skip a beat but it should be decent.
Just get some decent set of rca cables.
Monster cables cost to much.
For free it ain't bad.
Old Apr 27, 2004
Novaz3's Avatar
thanks i really appreciate that, so once i install it i should run all my bass through the sub right??? and only have my speakers running highs and lows????
Old Apr 27, 2004
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical forum
Old Apr 27, 2004
Novaz3's Avatar
Alright i need to get RCA wires but which ones and how many??????
Old Apr 27, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Do you have an aftermarket headunit? If you do then one set of 20 ft. RCA's should do the trick...any brand will work.
Old Apr 27, 2004
LudlamTheory's Avatar
i boogie for the raindrops
only use kimber cable.
its 100 dollars a foot
Old Apr 27, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
wats kimber cable?
Old Apr 27, 2004
doubledeuce2k2's Avatar
100 dollars a foot...
it's wire's. really pricey ones.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
JetsterDajet
52
May 8, 2016 12:11 AM
wingsfan19
Oct 1, 2015 03:45 AM
68camerors
Sep 24, 2015 06:18 PM
