amp mounting question!?!?
Old Apr 25, 2004
sage_'s Avatar
sage_ is an unknown quantity at this point
Question amp mounting question!?!?
Just built a new 2.25 cu.ft ported box for my one 12” L7 and I DON'T want to screw my amp ( http://www.mtx.com/caraudio/products...hunder801D.cfm ) or my 1.0 farad Lightning Audio cap to the back of my box like my previous system. I want to mount them both on the bigger rear fold down seat. SO, anyone got any ideas or experience concerning how I’m going to do this or what I should do???
Old Apr 26, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
what i did was cut a piece of ply wood and put it behind the carpet of the back seat and then mounted my amp to it. hope that helps.
Old Apr 26, 2004
sage_'s Avatar
how did you attach the ply wood to the back of the seat? that's my main problem cause there are those wire bars that go across the back of the seat andi don't have a clear idea on how to attach to wood to that.
Old Apr 26, 2004
doubledeuce2k2's Avatar
unzip the fabric and put the board inside there.
i'm using 1/8 basically pegboard material and secured the amp w/ zipties. put small holes in the fabric and run the zipties through, you'l;l be ok
Old Apr 27, 2004
sage_'s Avatar
well yea i was going to put the pre-cut board under the fabric, but i'd like to bolt down the board on the back of the seat some how so it doesn't move around at all; or for your car's does the fabric hold to board down?
Old Apr 27, 2004
the zipties pretty much hold it in place. they put the amp tight on the board and it doesn't go anywhere. just pre drill holes in the board and cut small gashes in the seat carpet
Old Apr 27, 2004
armjr2's Avatar
armjr2 is an unknown quantity at this point
i just drilled holes in the metal and used bolts think size #10 to hold the top of the amp and then zip tied the bottom holes to the metal bars
Old Apr 28, 2004
jmaz's Avatar
jmaz is an unknown quantity at this point
what i did was cut the ply wood about a half inch short on each side of the premeter of the back seat. i just sliped it in and then bolted the amp to the board through the fabric. it doesn't move at all!!!!
Old Apr 28, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
wow all that wrk for just a crapy install, if your going to do it, do it right, really plan it out and stay away from plywood ya...MDF is the choice of serious installers....but ya if your going to do it make it look kustom, not like ***, just like an amp mounted on the back of a seat..
Old Apr 28, 2004
jmaz's Avatar
so using mdf instead of plywood for something you will never see, just to make something stay on the back of the seat makes you the ****?? what are you 15 years old??? mr. serious installer! the whole point is the sound quality not for people to look at and say "i will be robing that tomm!" come live in NY your hard earned equipment will be gone in a week!
Old Apr 28, 2004
sage_'s Avatar
this is why i live in Michigan.... i'm thinking about just pre-cutting the needed size and amout of mdf to mount my cap and amp onto it. Then using U brackets to firmly attach the wood to the back of the bars of the seat.
Old Apr 28, 2004
KaZeLL's Avatar
wooo there buddie.. im just trying to help you out there..im just saying if your going to do it, do it right so that you dont have to do it again, or even it have it look like ***, i would want a cap mounted on the back seat in my car...Ill be more then glad to help you out of you want...and as for that profeshinal comment ..yes i am...little kid ...no im not 29yrs old and have done tons of show cars for APC,Bazooka,Audiobahn,Injen,Scion,Visonic,Boyde Cottington,hancook tires...and the list goes on on...
veiw this link
Old Apr 28, 2004
jmaz's Avatar
your work is top notch! but here is my question to you. what is the diff. between ply wood and mdf? it will go behind the fabric of the back seat! yes you are right if you are building something custom, like you obviously do, you would use mdf. but the question at hand is how to mount the amp to the back seat of the car. therefore ply wood/anything is fine.
disagree?
Old Apr 30, 2004
sage_'s Avatar
Does anyone know what that 8g sized black wire running down the pass. side kick pannels is? Radio wire possibly?
Also Keep coming with ideas and suggestions beside zip ties on how to mount my cap and amp to my rear seat.
Old Apr 30, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Old May 1, 2004
sage_'s Avatar
sweet instal however i amp and cap need to go onto the bigger rear fold down seat vs. onto the box.
Old May 1, 2004
Regularjoe's Avatar
Thats a custom board I made. Nothing is attatched to the box. Basically I made two boards. The one to the front is where everything is mounted and is sturdy and on an incline. The board to the trunk is an old piece of panneling that is vertical and just hides the wires from view.
mistermenphis22
Jul 13, 2015 04:43 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Ccoop87
Jul 9, 2015 03:26 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
BootyDo
Jul 7, 2015 06:06 AM
