Good bassy 6.5"s for the rear?
Old Apr 21, 2004
dan502's Avatar
dan502 is an unknown quantity at this point
Question Good bassy 6.5"s for the rear?
Being the dumbass I am, I ordered Infinity Kappa Series 693.5is for the rear speakers of my coupe. Now after reading a lot of the posts on this board, I have discovered two things: 1. The Kappas I ordered won't fit unless I perform a trunk shock mod; and 2. 6.5"s would probably do the job better as rear speakers than 6x9s.
Now here's my question, what's a good bassy set of 6.5"s? I listen to equal parts hip hop and rock, and I'm putting the Infinity Kappa 60.5cs in the front, so my highs will hopefully be covered. I would like the rears to add some bass, and that's about it.
Thanks.
PS Should I worry about amping that component system in the front? They will be running off 50Wx4 Pioneer.
Thanks again.
Old Apr 21, 2004
fonto's Avatar
The LA Clipper
IMO, if you have subs in the back it is better to leave the back holes open, or seal them without speakers. I always think that my subs would make my back speakers distort anyway.
Old Apr 21, 2004
dan502's Avatar
I will not be using subs because I use my trunk pretty frequently, but thanks for the advice. So any recommendations on those 6.5"s for the back?
Old Apr 21, 2004
doubledeuce2k2's Avatar
maybe consider sealing some 6.5" subs in the back. whatever you put back there will not be real bassy unless you try to seal it up some
Old Apr 21, 2004
LudlamTheory's Avatar
i boogie for the raindrops
nothing aftermarket will be bassy running off a deck
Old Apr 21, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
i think pioneers are ok...
Old Apr 21, 2004
dan502's Avatar
Ok, I really don't want subs in the trunk, just some decent bass, I'm not into huge amounts of bass, just a decent amount is good for me. a good pair of 6.5"s will work for me, i just need some recommendations. on the other hand, is it crazy to ask if it's smart/possible to mount subs in the rear where the 6x9s currently are? would i have to rig some enclosures for them? yes, i would get an amp for them, since i will probably want some extra juice for my components. thanks for all the responses.
Old Apr 21, 2004
dan502's Avatar
i'm not really thinking logically about this (i'm talking on the phone at the same time) it's prob not possible to even mount subs like that, is it?
Old Apr 21, 2004
Ed's Avatar
Ed
Maybe get a set of 6.5" subs, yeah, they won't hit low like a real sub, but there's gotta be somethign though, right? I don't knwo how they'll do in an IB setup though :-/
Old Apr 21, 2004
dan502's Avatar
where can i find 6.5" subs? i've looked at crutchfield.com and sounddomain.com, and didn't see any that small. would they be under another category than subwoofer?
Old Apr 21, 2004
WhiteRabbit's Avatar
Adire Koda, in .3 sealed, or freeair, or ported
DD w6.5, in .5 ported with a crapload of power (but in no way freeair)
lud, you didnt reccommend CSX? tsk tsk.... its made by peerless
Old Apr 21, 2004
and the CSX are only $40 each, too
Old Apr 21, 2004
dan502's Avatar
sounds good...where can i find them? thanks, i found something on sounddomain but i'm not sure it's what you're talking about.
Old Apr 21, 2004
http://www.speakercity.com/Peerless_files/csx165c.shtml
Old Apr 21, 2004
http://www.adireaudio.com/mobile_aud...ers/koda_6.htm
http://www.adireaudio.com/Merchant2/...gory_Code=2000
Old Apr 21, 2004
http://www.ddaudio.com/caraudio/woofers.asp?series=W6.5
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
leon1
Apr 28, 2015 07:32 PM
superstanko
Apr 28, 2015 04:38 AM
