could this be the problem?
Old Apr 9, 2004
bizkit's Avatar
bizkit is an unknown quantity at this point
im reading in my little kicker book here and it says that the dual 4 ohm woofer will give a 2 or 8 ohm load, depending on how there wired... and the dual 2 ohm will give a 1 or a 4 ohm load depending on wiring, whatever, so i have the dual 4 ohm woofers wired at 1 ohm... could this be the reason why it sounds like crap? should have the dual 2 ohm instead? also i have blown 3 of these woofers in less than a year. twice ive fried 2 of the 4 wires that are come from the voice coils i believe, and another time the yellow wavey thingy under the cone cracked. could that play into this?
Old Apr 9, 2004
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
what kind of amp are you using?
Old Apr 10, 2004
bizkit's Avatar
kicker kx1200.1 for 2 12L7s
Old Apr 10, 2004
MegaHurtz's Avatar
How do you wire a dual-4 ohm sub to 1 ohm?
You might even not have enough power for those subs, depending on how strong your electrical system is.
On a stock alternator and stock battery, especially with improper wiring, that amp would not be producing anywhere near enough to make those Kickers happy. A 1200.1 is a really nice choice of amp for that pair, but they've gotta have the power to back it up.
Old Apr 10, 2004
bizkit's Avatar
sorry i guess its not at 1 ohm cuzthe dual 4 ohm will only go to 2 ohm, is that right? so i need the dual 2 ohm to get 1 ohm? i do have a svr battery in the trunk too, doesnt that give enough power?
Old Apr 10, 2004
rinsincivic's Avatar
rinsincivic is an unknown quantity at this point
dual 4ohm bridged parallel with 2 subs would put you at 1ohm
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
