sub troubles
Old Mar 28, 2004
tdub4life's Avatar
sub troubles
I was driving home one day, with the music volume low (surprisingly, hehe) and i notice after a few minutes that my woofers arent hitting any more. figured it was a connection problem, so i just waited until i got home.
when i did get home, i popped open the trunk and found that the power cable was out. so i screwed it back in and turned on the car again to make sure it worked.
....but it didnt. so i checked the fuse, and it was fine. then i checked to make sure the amp was being powered, and it was fine. then i took one of my subs out of the box and checked the voice coil to make sure it wasnt blown, and it was fine.
im completely dumbfounded....
any ideas guys?
Old Mar 28, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
check your signal cable?
Old Mar 28, 2004
tdub4life's Avatar
signal cable?
do you mean the remote line ? or the wire connecting the subs to the amp? or...
Old Mar 28, 2004
doubledeuce2k2's Avatar
RCA wire. with the 2 plugs. goes to radio
Old Mar 29, 2004
tdub4life's Avatar
Oi, i realized that after i re-read his post.
Thanks, i'll check that out.
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
Bruce2
Sep 21, 2015 08:01 PM
