cap question...
Old Mar 3, 2004
slicksivik's Avatar
cap question...
Well i was driving at night and i put the bass on even tho i rarely use it and i was looking at the car in front of me and i noticed that my lights looked like they were flashing everytime the bass hit. thought it was kinda amusing, lol. Anyways, since i need a cap im guessing, is it easy to install, like a digital one? Just plug in or lots of wiring? thanx
Old Mar 3, 2004
WhiteRabbit's Avatar
its cake. pos goes to yoru D block, neg goes to any ground.
if you have no D block, cut yoru power line ANYWHERE and put a ring terminal on both cut ends.
then screw both rings to yoru cap and ground neg, its that simple!
only thing ot remember is to charge it if its discharged, your cap will come with instructions.
Old Mar 3, 2004
stupidd's Avatar
stupidd is on a distinguished road
cool, i didnt have to start a thread.
also, what are some pricing for these? and about the Farads... what number of farads would be good for what number of watts on an amp? or whatever.
thanks
Old Mar 3, 2004
sometimes 1 farad is enough, sometimes many farads are required. its different for every situation, and empirically derived.
i think they are on ebay for $25ish per farad. i think.
Old Mar 4, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Just out of curiosity, how do u charge and discharge a cap. I lost my manuel that came with my cap.
Old Mar 4, 2004
doubledeuce2k2's Avatar
to charge a cap you need to put something inbetween the power wire and the cap terminal. like a resistor or a test light. a 1k resistor works great. test light is good because when it goes out, you know that the cap is mostly charged. hold the resistor/light there for about a minute to be careful, then directly connect the power wire to the cap.
Old Apr 26, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
does any have a pic of their cap install?
thank you!
Old Apr 26, 2004
fonto's Avatar
The LA Clipper
thank you!
Old Apr 26, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
its easy. but it might not solve you light dimming problem.
caps arent to solve that they r there to ease the strain on the alternator. so dont think its not workin if your lights still dim.
it all depends on the wireing of the car. it stopps some cars and doesnt on others.
Old Apr 26, 2004
not to be an ***, but i think 99% people put caps in to reduce dimming.
and they would increase alternator strain if anything
Old Apr 26, 2004
it is a capacitor all it does is hold voltage so when the bass hits (high current draw) it doesnt take from the battery witch suddenly makes the alternator work harder. the caps fufills the amps needs and the battery fufills the cap in ter easing the electrical system.
ALOT of people r missunderstood about caps!!
and its proven that it decreases alternator stain.
i would do a lil more research double b 4 offering advice i spent a month in installer training and installed for 2 yrs.
btw: im not tryin to be a d!ck
Old Apr 26, 2004
could you show me where its proven that it decreases alternator strain, please?
i mena, id believe it based on my own experience, because when i had a cap connected in my car, the alternator would never bump up to 14 volts unless I was over 3500 rpm.
of course, the battery died a whole lot, it was never charging!
but that seems to me to be a cop out of a reason for reducing alternator strain.
so im wondering what your proof is for the reduction of alternator strain?
Old Apr 26, 2004
http://www.infinitecaraudio.com/cgi-...ory=Capacitors
"help your alternator last longer"
just what i found quick
like i said i also have product training for every maker circuit city carries in the roadshop.
i wish i could link that thats the perfect example but its secure.
Old May 23, 2004
dapakione's Avatar
dapakione is an unknown quantity at this point
my friend has a rockford cap and his car does not dim at all with a jl w7 in his car, i have no cap and it dims with a infinity basslink, so i think the caps work, as long as they arent cheap? what u guyz think?
Old May 23, 2004
Remember guys, the cap gets it's power from the alternator. So everytime it discharges, it has to juice up again from the alternator. This puts excess strain on the electrical system and may even take away hp.
Old May 23, 2004
draganjr's Avatar
So Caps are bad?
Old May 24, 2004
I wouldn't get one and I have two amps. No problems after all the upgraded grounding. I don't even think the headlights dim when I turn on the deck anymore.
All caps do is reduce dimming. But understand from above that dimming isn't really a bad thing. It's just that the alternator can't keep up, and the car accessories switch over to 12V battery power. So the headlights are dimmer at 12V. The cap won't really fix anything, just fool you by making the dimming go away. The cap just acts as a quick charge battery that draws power from the alternator.
Old May 24, 2004
On another note, that HVS I have also acts as a capacitor for the whole car. But that one is supposed to prolong battery life and help voltage move more smoothly.
Old May 24, 2004
http://www.betteraudio.com/geolemon/newmain/battcapalt/
benefits and disadvantages to ugraded wiring, "the magic three" capacitors, batteries, alternators, etc.
Old May 24, 2004
MegaHurtz's Avatar
Rule of thumb is .5 farad per 500 rms watts of power, 1.0 farads per 1000 rms watts and so on.
My question for this thread is what happens if I don't charge my cap before I install it? Do they not charge themselves by definition of what their function is?
Old May 24, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
WR, that link doesnt work
Old May 24, 2004
they charge jsut fine, its jsut a good idea to charge it manually the first time due to the intense surge of current when its completely drained.
in DC voltage, a capacitor is a dead short when 100% drained. the battery doesnt like this, the capacitor doesnt like this! its not uncommon for capacitors to destroy themselves with such an impact charging!
so we add a resistor inline the first time so its not a total dead short.
after that, the cap never discharges past the voltage of teh battery, so it can handle surges just fine. its not a total dead short!
mystic, bart's server is down right now, itll work when its back up! its actually a very very good read
Old May 24, 2004
MegaHurtz's Avatar
So if I never charged my cap initially, should I do it now?
Old May 27, 2004
BRCivic's Avatar
BRCivic is an unknown quantity at this point
btw, I upgraded to an Optima Yellow-top grp51 about a week or two ago, and it helps absolutely none with lights dimming... they dim just as bad with the Optima as they did with the stock one
Old May 27, 2004
Old May 27, 2004
fonto's Avatar
The LA Clipper
a good read...thanks for the link
Old May 27, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Sometimes just replacing the grounds with larger wire from your battery to your frame, alternator, and engine help remove dimming.
It could be your friends car has decent wiring for his grounds and you don't. I've heard (take it with a grain of salt) of people running 2000K RMS without needing a cap. And most get a second battery instead of a cap.
Old Jun 1, 2004
dapakione's Avatar
so the cap, has no negative effects, so i guess ill install mine in, thas all i wanted to know anyways, that was a really nice read, thanxs alot white rabbit
Old Jun 1, 2004
be careful, you might find unforseen undesireable effects, like drained batteries!
not saying it will for sure happen, but definitely be on the lookout for potential negative consequences!
Old Jun 1, 2004
MegaHurtz's Avatar
My battery has never been drained yet..
