Will this Amp + Sub setup work?
Old Feb 23, 2004
skiboard's Avatar
I am noob on sound systems so please help me out
I bought these subs and amps, would this work?
2 x 400 Watts RMS at 4 Ohms
2 x 800 Watts Max at 4 Ohms
1 x 1600 Watts Max at 4 Ohms Bridged
2 x 650 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H
10-inch JL W7
500w rms
3Ohm single
Old Feb 23, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
to me it seems as it will work but you will only know once you hook it up.
Old Feb 24, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
So you got one of the best subs on the market ..... then got one of the cheapest amp out there......
Old Feb 24, 2004
LudlamTheory's Avatar
i boogie for the raindrops
wont work.. 10w7 is single 3 ohm, that amp is only stable bridged at 4 ohm, youd blow the amp...
Old Feb 24, 2004
skiboard's Avatar
Dang, no way it's going to work? yeah, I bought the amp before sub. I would have bought 1/500 if I knew I was getting JLs
Old Feb 24, 2004
so return it, or sell it, or give it away, or burn it, or put it in your closet, and get yourself a respectable amp.
jl 500/1 would work, or any amp that would give you 500-800 watts at 3 ohms.
someone give him more options, i dont feel like searchin
Old Feb 24, 2004
skiboard's Avatar
would it possibly do any damage to sub tho? or is it not worth tryin?
Old Feb 24, 2004
no damage to teh sub most likely, but you an still make some money off that amp without risking blowing the crud out of it
Old Feb 24, 2004
skiboard's Avatar
Hmm.. yeah but I dont have any $$ to get 1/500 now, so I was planning on saving up while using this amp and sell/whrow it away to buy 1/500s after. Hmm.. how many watt would it be producing if I use this lanzar with 10w7 by the way? sorry I am dumb with these.
Old Feb 24, 2004
SubstanceX's Avatar
SubstanceX is an unknown quantity at this point
are you in need to power them that badly?
I would seriously save up and get a decent amp. You won't regret it in the end.
Old Feb 27, 2004
Dainfamous's Avatar
Dainfamous is an unknown quantity at this point
man i give u 10 dollers for tha amp
Old Feb 27, 2004
fonto's Avatar
The LA Clipper
This cracked me up!!!!
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ORskier
May 3, 2015 12:54 PM
GH04si
Apr 15, 2015 08:13 PM
mohawkboom
Nov 2, 2001 06:00 PM
