Fuse problem!!!
Old Feb 9, 2004
  #31
Regularjoe's Avatar
Regularjoe is on a distinguished road
Hang on. Your confusing the crap out of me.
You need something to protect the car next to the battery. This is so that if the cable shorts out it doesn't light the car on fire. This can be a agl fuse, anl fuse, OR circuit breaker. You choose the style that you want. The size has to be EQUAL to or MORE than the sum total of all the fuses in your amps. If the new 4 guage kit comes with an anl 80 amp fuse, simply buy an 100 amp anl fuse and put that in here. Otherwise you can buy a circuit breaker and put it in its place instead, eliminating the need for the anl fuse and holder.
You also have a fuse on the amp itself that protects the amp. This isn't swapable. You need to replace it with the exact type and size thats there originally.
Old Feb 9, 2004
  #32
Regularjoe's Avatar
Yes, that Rockford 100 AMP fuse and holder would be fine. Simply replace the fuse and holder that comes in the kit with that one. This is the one that goes by the batttery.
Old Feb 9, 2004
  #33
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i think i found what i need
Power Kit for Amplifiers up to 1400 Watts
18 feet of 4 ga. Custom PRO Red Power Wire
3 feet of 4 ga. Custom PRO Black Ground Wire
1- 24kt Gold Plated ANL Fuse Holder with 150 Amp ANL fuse
17 feet of 18 ga. Amplifier Remote Turn-on Wire
1- 24kt Gold Plated Super Surface Contact Grounding Terminal
10- 7 inch wire ties
Full Assortment of 24kt Gold Plated Terminals and Hardware
Protective, Snap-in Wire Grommet
regularjoe and keepin it clean are my new best friends
Old Feb 9, 2004
  #34
Regularjoe's Avatar
That should work perfect.
Old Feb 9, 2004
  #35
sadboy916's Avatar
thanks to everyone i was not sure what to do at all now i see the light
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
roverben
Jan 21, 2019 05:16 PM
beveragemp
May 25, 2015 07:11 PM
steveneddy
May 19, 2015 02:39 PM
