removing si/sir headunit ?
Old Jan 30, 2004
02stockcivic's Avatar
02stockcivic is an unknown quantity at this point
help... anybody know how to remove the stock stereo from a civic si/sir. ?? I've tried what I can without taking a chance at damaging the dash... and I can't find anything on this anywhere.... Thx
Old Jan 30, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
DO NOT pry it out from the dash....DO NOT DO NOT!!!!!!
remove center console.....remove 2 screws under the dash.....push hard from the inside on the metal frame.
go to DIY section i think they got pictures there.
Old Jan 30, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
i found a diy for what is supposed to be the 02-03 US Si civic headunit install. it masy or may not be correct. you may want to check with someone that owns one before trying this, but this said 2002-2003 civic si HU removal. anyway, i copied and pasted, here ya go:
-Remove the panel below steering column ( 3 visible screws )
-Remove the now-visible 2 brass colored phillips screws on left of the panel under the radio ( the 12v outlet is mounted on this panel )
-Empty the Glove Box and pull in the tabs at the top so the box opens all the way pointing down
-Remove now-visible 2 brass colored phillips screws on right of panel under the radio
-Remove the 2 brass colored screws at the top of this same panel
-Remove Panel
-You can now get to the two silver 8mm bolts holding the bottom/back of the stock radio in
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
