0G Power Wire?
Extreme Member
0G Power Wire?
Hey everyone, I decided that since I already have a great box for my JL 12w3v2 that I built, I don't want to buy another 12w3v2 and have to build another ported box to accomodate it. I still want to fix up my system and customize it. Heres the thing, my two amplifiers, Alpine M300 and HiFonics ZX6000 are connected with a 4G Power wire and 8G power wire. I am planning on removing the amplifiers from the back of my back seats and build a custom trunk bottom with boxes beneath it to put the amplifiers and put some clear covering over the amplifiers to make them viewable. I want to have one power wire though to run all the way to the back and then get a fuse terminal to split the power among the amplifiers. Will a 0AWG wire bring enough power to run my two amplifiers?
i boogie for the raindrops
you wont need 1/0 gauge under any circumstances till you break the 1.5ish kilowatt range at least, if not more. to go even farther. I have an amplifier sitting in my garage that will do 1600 watts rms without breaking a sweat (whiterabbit will back me on that fact) and it only accepts 4 gauge
Yup, or you could get 2 AWG if you wanted to split a couple 4 AWG lines. It's really just about how you want it to look
I like the way big fat cables look, so I ran 0AWG into a fused distro block with a plexi window and status lights and all that stuff.
I like the way big fat cables look, so I ran 0AWG into a fused distro block with a plexi window and status lights and all that stuff. The LA Clipper
I use 4 guage to a distro block with 2 4 gauges coming out of the block...my amps are right behind my back seat and they hardley ever get warm...never hot, and never have shut-off. I think my amps are rated 1500 watts RMS.
Extreme Member
Im guessing that since my HiFonics Amp is rated at 150W RMSx2 and my Alpine is rated at 300W RMSx1 that I can just use the existing 4G wire to easily power both with a distribution block then.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Dmitri
123
Oct 13, 2005 08:01 PM
use either 4 or 8 gauge from the dist. block.
