amp install on the back seat
Old Jan 13, 2004
mrb420's Avatar
mrb420 is an unknown quantity at this point
I want to install a FS amp on the back of the 2/3 seat in my coupe. But, the seat does not have a hard back it is just the foam and a couple of bars. Does anyone have any suggestions on how to mount the amp to the back of the seat? I was thinking of using a piece of wood and attatching it to the bars somehow then put the carpet over top it?
Old Jan 13, 2004
BRCivic's Avatar
BRCivic is an unknown quantity at this point
All you gotta do is unzip the carpet and slide a flat piece of wood that's about the same size as the back of the seat, then just screw the amp through the carpet into the wood. Works great.
Old Jan 13, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Yup...slide 1/2" or 3/4" MDF underneath the metal bars, then screw the amp right into the wood.
Old Jan 13, 2004
mrb420's Avatar
thanx, thats what i figured would be the best solution.
Old Jan 13, 2004
mrb420's Avatar
MDF?
Old Jan 13, 2004
Mystic3030's Avatar
Medium Density Fiberboard...it's what sub boxes are made of. You can get it at Home Depot or Lowes.
Old Jan 13, 2004
mrb420's Avatar
Should I put a nut on the screw after it goes through the wood?
Old Jan 13, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
all i did was shove a piece of plywood the size of the 2/3 seat under the fabric and zipped it back up. the amp has been holding there fine for over a year. another possibility would be to use zip ties to go around the bars in the seat and then through the screw holes in your amp. i used this method for my XM tuner and mounted it to the 1/3 seat and it works great.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
JeffSpeed21
Nov 3, 2001 10:32 AM
