issue with system HELP!
Old Jan 12, 2004
PCaly2112's Avatar
PCaly2112 is an unknown quantity at this point
Question issue with system HELP!
While driving and listening to cd, radio, whatever my sub will stop working. I'm running a Concept 350x2 amp bridged to a Polk/Momo 10" sub, with lightning audio 4 gauge amp kit. What could be causing this? I've checked all connections and fuses and they seem to be good. A friend suggested its cause the amp isn't capable enough of powering this sub at some of the levels i may have it at. Is there anything else it could be?
Old Jan 12, 2004
alex053's Avatar
your gain may be to high, you may have a bad ground, you may have the amp bridged at too low of an impedance that the amp can handle,
Old Jan 13, 2004
Either it's wired wrong, or you're pushing the amp too much. If it's the second thing, the amp may turn off to prevent burnout.
Also check your ground, as mentioned already. Make sure it's screwed tight to bare metal--not painted.
Old Jan 13, 2004
PCaly2112's Avatar
Thanx for the help, just to add to this i dunno if it'll help but it always shuts off at the same exact points in certain songs, so thats kind've leading me to think that i'm pushing the amp too much, im gonna check my ground too, i don't exactly remember if its to a painted surface or not
Old Jan 13, 2004
Find and play music that has alot of base notes. Christina Aguilera's new stuff comes to mind. Or rap music. When the bass hits, the amp will be drawing alot of power.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
TiggerDX
Jun 18, 2015 01:43 PM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
bluecoupe
Jan 30, 2002 08:43 PM
