Cutting away metal door trim to fit speakers?
Old Jan 11, 2004
BomberNYC's Avatar
BomberNYC is an unknown quantity at this point
Sup! helping a friend out installing his infinity kappa speakers. Just like all kappa speakers, the magnet is huge and will not fit the door. My question is for people who've cut the metal hole where the stock speaker goes into, what did you use to cut the metal? you guys thing a dremel would do it?
Old Jan 11, 2004
WhiteRabbit's Avatar
dremel would work. easiest way is to cut slits that radiate out, like sun rays, then hammer back the tabs. also sawzall, air saw, or even some gnarly tin snips would work pretty good.
Old Jan 12, 2004
DarkEdge's Avatar
DarkEdge is an unknown quantity at this point
The first night I used a pair of pliers. It was too late and the dremel/jig saw was to loud. It looks just like I did it professionaly because the next day I took the grinder to it. : ) As for the otehr side I used the jig saw, and then grined it again, and then primed it up. That way I don't get any rust.
When it comes time to mount the speakers your gonna have to make a bracket for them. The one that comes with the kappas will work, however, when you roll down the window it will smack the speaker. I don't know the depth of the bracket you will need however. I had a leak in my door and it ruined mine so I went to kick panels.
Old Jan 12, 2004
doubledeuce2k2's Avatar
good job with speakers darkedge. welcome to the forum.
post up some pics and/or tell us what your running sometime.
Old Jan 12, 2004
right, post cutting a speaker baffle made from MDF at the appropriate thickness is the way to go.
1" thick for a 3" deep speaker, less for lesser speakers.
Old Jan 12, 2004
DJPark's Avatar
DJPark is an unknown quantity at this point
I used a dremel to make the metel thinner and weak. I went through at least 20 grinding bits to cut through a hole big enough for my speakers. I then used snipper things to cut all the way through. Then I had to make a spacer out of plywood so it would fit without hitting the window. What a pain in the *** all this was.
Old Jan 12, 2004
DarkEdge's Avatar
Thanks. When its done I'll post. Right not I have the 1st have of my sytem done, just trying to find a place to buy a high output alt. from. I can find 93-00 alts for civics, just not the 01+ yet.
Old Jan 12, 2004
dominick iraggi, he will rewrap our cases
Old Jan 12, 2004
civic01vtec's Avatar
how many watts u running ?
just upgrade ur primary battery to a red top first and see if u are happy with that.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Tedverseti
Apr 23, 2020 01:45 PM
doublins
Nov 11, 2001 07:01 PM
CivicHX01
Nov 2, 2001 08:49 PM
mohawkboom
Nov 2, 2001 06:00 PM
