amp remote wire ? (Audio peeps please help)
Old Jan 2, 2004
JoeyCrac's Avatar
JoeyCrac is an unknown quantity at this point
Question amp remote wire ? (Audio peeps please help)
What wire do I hook up my amp remote wire too? What color is it??? I hooked up the system last nite, wverything works perfect except I hooked the remote wire to the power wire on the radio and the amp doesn't turn off with the radio??????????? Heeeeeeeeeeeeeeeeeellllppp Me!
Old Jan 2, 2004
JoeyCrac's Avatar
ttt
Old Jan 2, 2004
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
the wire should be blue and it should hook up to remote amp turnon or accesory the remote amp wire should be blue and the accessory orange hope that helps
Old Jan 2, 2004
Civic02playa's Avatar
Civic02playa is an unknown quantity at this point
Exactly what bigainabuilt said.......it will be blue and there should be a wire off the harness that it will hook up to.....you might either have to solder it together or clip it together, regardless it will be there and it will be blue......i've hooked up about six systems for myself and my buddies and i have never seen one that hasnt been blue
Old Jan 2, 2004
JoeyCrac's Avatar
yeah, but what color is the wire on the wire harness in the back of our stock radios that i connect the blue rem wire too??? There is no blue wire in the wire harness for the 2k1 stock radio.
Old Jan 2, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
ahhh, since you are using the stock radio, you need to tap the igniton wire, or the cig lighter + wire. Another option is using a toggle switch.
Old Jan 2, 2004
JoeyCrac's Avatar
I hate toggle switches, i'll forget..........anyway, I guess I'll put it on the cigarette (+) wire........are you sure this will work?
Old Jan 2, 2004
doubledeuce2k2's Avatar
yes. that wire is yellow (just in case you didn't know/couldn't figure out)
Old Jan 2, 2004
WhiteRabbit's Avatar
yeah, ciggarette lighter is on accessory (at least in my car) or you can tap ACC rather than constant. the amp will be on as long as the car is on, but will shut off with the car, not the radio.
standard shop installation on a stock radio.
Old Jan 3, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
be carfull i had some subs hooked up and the idiot at the shop hooked up the remote wrong and everytime i turned off my radio the subs went full blast. Scared the **** out of the honda mechanic
Old Jan 5, 2004
JoeyCrac's Avatar
thanks, i hooked it to the cig(+) and It's bangin to perfection
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
