power exceeds wiring limits?
Old Dec 28, 2003
reytito's Avatar
so i'm curious if 550W rms is too much for an 8 guage wiring kit, which is rated for 500W. i mean...do i have much room to go over? what can potentially happen? also...i believe that the amp's pwoer rating might be underestimated (rockford fosgate power series) ...
thanks
Old Dec 29, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
you'll be fine with 8 guage on a rockford 550 watt amp
Old Dec 29, 2003
doubledeuce2k2's Avatar
what fuse is on the power wire? if its 80 or bigger i'd say get maybe a 50 or 60 amp and that would protect you just fine. don't worry about the wire thickness though, 4 gauge upgrade would hardly be noticable ever.
Old Dec 29, 2003
tfnaaf's Avatar
BLDNPSI Mod
Your amp wattage has ZERO to do with the power wire size. What does matter is the amprage that the amp can draw, and the distance that it draws it from the batter. These 2 things will determine the size of wire that you need. Ill see if i can find the chart for this
Old Dec 29, 2003
tfnaaf's Avatar
BLDNPSI Mod
Old Dec 29, 2003
but see amplifiers are about 50-75% efficient (depending on class and many other things). this is not an exact science, and the fact is his current wiring setup in no way is hurting the amp or his car significantly.
i have had one amp that told me max current draw in the manual. fuses don't tell you a thing really either about max current draw.
Old Dec 29, 2003
tfnaaf's Avatar
BLDNPSI Mod
im not saying he is hurting it. Im just stating the proper way to determine the wire size. Best way to determine wire size is look up amp specs , they usually list max amps draw. Measure the distance of your wire. Then figure out the best wire size for your need. Its always best to have too much then not enough.
Old Dec 30, 2003
JohnDoe's Avatar
Like I said, with a ROCKFORD 550 watt amp you will be fine with an 8 guage power wire.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
darwin-t
Apr 18, 2015 09:29 PM
Dmitri
123
Oct 13, 2005 08:01 PM
Mary
Jan 2, 2002 06:42 AM
supercivic01
South
Nov 30, 2001 11:27 AM
