car audio problem
Old Dec 23, 2003
shmik1's Avatar
Question car audio problem
has anyone had a problem with engine noise? I had system installed at circuit city and I had it in for a good day and a half trying to fix a noise problem, with the system off i can slightly hear a small whine.. (normal im told.. let me know if no one else has this noise, maybe its not?) anyway, it seems to be coming more from the rear speakers, although both are wired up to the same amp, different channels tho so it seems possible to me, anyway, circuit city ordered me a new amp to switch it out and see if thats the problem, fine by me.. a new amp couldn't hurt! So does anyone have any tips, ideas or anything to help me out? (or rather help them fix it, im not sure what they're planning to do next if the new amp doesnt fix it) they suggested I make this post and see if anyone else has similar problems.. so if anyone can help me out, i'd appreciate it!
Old Dec 23, 2003
tripledoublegs's Avatar
Euro-Spec
That's why I always install my own s**t.
Old Dec 23, 2003
eye_see_you's Avatar
let the devil out
what you hear is alternator whine and it is not normal with a correct install. Ways to help fix the problem is to:
1. Have a good quality Amp
2. Have the correct gauge power running to the amp (4 gauge, 8 gauge) depends on the size of the amp
3. Have the same size ground wire as the power wire and close to the amp the shorter the distance for the ground the better.
4. check your battery leads to ensure they are grounded to the car
if all else fails look for a noise loop isolator its a filter basically
Old Dec 23, 2003
targetpractice's Avatar
targetpractice is an unknown quantity at this point
one thing I learned, its going to sounds crazy. If your head unit has a crossover and you amp has a crossover and both of them are turned on, I found that it has a lot of engine noise. I had the same problem, I destroyed a few panels in anger trying to figure it out and after I had checked all the wires I started looking at the amp. Well I decided to turn everything off on the amp, and turn the volume all tha way down, you know just like when you are first tuning it, and when I did that I noticed I had no engine noise, so I played around a little longer and turned the crossover back on and boom, noise was back. Same thing as you have, louder in the rear then in the front. No lie, it worked for me, I know it sounds crazy but its true
Old Dec 23, 2003
FaLKoN202's Avatar
FaLKoN202 is an unknown quantity at this point
My friend told me that the ppl at Circuit City suck at installs, but maybe that's just in the Bay Area. (or where u are, too)
Old Dec 23, 2003
7thGenerasianCivic's Avatar
Maybe you are having some sort of interference with the electronics in your car. haha I dunno.
Old Dec 23, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
samethign with philadelphia. my freind bought an alarm there and wanted to get it installed and the installers said "we dont knwo how install alarms yet, we are still learning, only systems". if an installer doesnt know how to install an alarm then he will not be messing with my car
Old Dec 23, 2003
jackscivic's Avatar
jackscivic will become famous soon enough
i actually went into curcit city or best buy ( i dont remember cuz it was like a month ago) and i asked them random car audio questions that a basic car person would know. well as it turns out all they do is bs there way outta the questions... for example this one guy didnt know why you need the proper size power wire for an amp. there totally stupid. thats why i got to excessive audio or tweeter around here for not only my componets but my installs if i cant do them.
Old Dec 23, 2003
shmik1's Avatar
well I know that some chains have people who are dumb, bestbuy for example when i went there they didn't know a whole lot about what they were doing, the guy I deal with at circuit city let me check out his system and im very happy with the work he does, i would do all this myself but im not experimenting with my new car, so i leave it to people who know what they're doing (or atleast have insurance from a chain :P)
the 2 guys who did to my knowledge all of my installs are VERY knowledgeable and have never said anything or done anything to make me doubt their expertise, which is why I am a repeate customer. I know it's better to do it yourself, but I don't really have the experience or know how for this. btw, if you want to see pics of my system they're posted on sounddomain.
http://www.sounddomain.com/id/shmik1 <<< check it out (I definitly am happy with how things have turned out)
targetpractice: I'm going to check it out right now my head unit and both my amps have crossovers. So i'll see wut i can do i'll prolly do that soon and post another msg, let ya know if i could get it or not.
Old Dec 23, 2003
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
its a problem that can happen wtih a correct intsall but poor judgement in ground .. ill be 20 buyx if you go back and tell them .. to reground it it will go away
Old Dec 24, 2003
SMBFC's Avatar
SMBFC is an unknown quantity at this point
If there's a mod out there, send this to ICE, ludman, white rabbit, and a few others are awsome, you should have this moved to ICE so that they can look at it.
Old Dec 24, 2003
cambo's Avatar
I wish I was asian
also, you might want to ask them where they installed the RCA wire and power wire. They SHOULD be on seperate sides of the car, as the RCA can pick up interference form the power wire which causes the whining noise.
Old Dec 24, 2003
player's Avatar
its probebly the wires, there should be no whine, i got my system installed at futureshop ( the equivalent of best buy in the states) and there is no niose, buzz or noise of any kind, it probebly the location of the wires and the connections.
Old Dec 24, 2003
player's Avatar
ph yeah
wrong forum
Move this to ICE
Old Dec 24, 2003
Nick Burns's Avatar
Nick Burns is an unknown quantity at this point
you need proper grounding.
Old Dec 24, 2003
LudlamTheory's Avatar
i boogie for the raindrops
1 - wrong - introduction of noise into any system is in no way dependant on amp quality. all an amp does is takes a signal and makes it bigger. the noise is let into teh system somewhere before tha mp, and the amp amplifies it. you could take his noisy RCA, hook it up to a $10,000 brax signature amp and guess what, still get a noisy signal.
2 - wrong - power wire gauge has nothing to do with noise intereference either. Too small of a power wire causes 1 of 2 things, shutoff due to low voltage, or teh wire melting.
3 - hes right on this one
4 - if teh battery leads werent grounded to teh car, the car wouldnt turn on
Old Dec 24, 2003
what teh f*ck is wrong with your stereo.....
ive installed countless amounts of systems and ive never heard **** like that before
Old Dec 24, 2003
alternator whine is a weird thing.
sometimes you try and try and try and try and you keep getting it, no matter what.
i had one guy, not only did he get whine, but everytime he hit the brakes he'd hear a pop because his amps were grounded too close to the taillights.
if you really cant get rid of it, youve just gotta eliminate components down teh line.
take a little portable cd player with a headphone to rca cable and plug it into the amp, see if you get nise, you do, its teh amps grounding, you dont, its not
move over to teh radio, plug the little cd player into your rca cables on the front side of the car, so you can see if the noise is coming somewhere through where teh rca's are.
noise, reroute the rca's,
no noise, move on.
finally, plug em back into teh deck.
noise, reground your deck, rearrange your wires behind teh radio, no noise, no noise.
if its your amp ground make sure teh area is bare metal. sometimes though you just get to an area where the metal is just straight up weird and you cant seem to NOT get noise.
Old Dec 24, 2003
I hear you one that one, I have installed countless stereos as well. strangest thing I have ever seen. It drove me nuts, I tried changing the ground location, ground wire, then I moved to the RCA, ran RCA's right from the HU to the amp, still noise, took inside and hooked it up to my power converters and still got noise. I went through everything possible it could be, and as a last act, or prayer, I turned the crossover off on the amp and it worked fine. Everything is working fine now, and no I know its not the amps, for mids and high, I have an Xtant and for the subs I have an Rockford X-7, all the wires were high grade monster cable and the HU is a Kenwood Excelon 969.
Old Dec 24, 2003
sometimes 2 things just dont agree...
but thats also because headunit crossovers tend to be shitty as hell to begin with.
also, personally, i use radio shack $5 rca cables with absolutely no noise to tehm...
Old Dec 24, 2003
shmik1's Avatar
they mentioned that they swapped the deck to see if that was the problem, and it's not so thats not it... i tried last night to turn off the amp crossovers to fix it, strange tho, it seemed like it helped a little, i could still hear it, but didn't seem to be as much, then as i was driving around i noticed i heard a different noise more in the front so i just switched it back and im gonna let em know about everyones suggestions... so hopefully we can get this fixed soon [they ordered me a new amp if i didn't mention that - i dont think its the problem and i dont think they think it is either but they ordered it for me just incase... since that would make it easier]
Old Jan 14, 2004
2k1civic's Avatar
2k1civic is an unknown quantity at this point
/\ did you find out anything about your noise problem? Did the amp replacement fix it?
Old Jan 14, 2004
shmik1's Avatar
its been about two weeks since i've talked to them as far as i know it hasnt even come in yet..
Old Jan 14, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Make sure the ground is very tight and clean. No paint or anything in there.
Also make sure the RCAs and the Power Cables are run on opposite sides of the car. Keep them as far apart as possible. Never have them side by side.
Tedverseti
Apr 23, 2020 01:45 PM
dooner24
Apr 14, 2015 07:51 PM
Slickwillie
Nov 5, 2001 03:48 PM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
SILVERCASE
Aug 2, 2001 02:19 AM
