Punch HX2 with a Punch 601S? (confused)
Old Dec 20, 2003
7thgencivicdriver's Avatar
7thgencivicdriver is an unknown quantity at this point
well i bought a RF 601S amp planning on running my two infinity refferences of it. well then I said **** it and decided to splurge on new subs also, so I bought two 12" Punch HX2's. My question is (I have yet to receive them so I wanna ask before I install) the subs are 4-ohm each and the amp list 300wrms @ 2ohm, so if I were to wire them normal (+ to +, - to - on each channel) wouldnt that make it so the speakers were 4-ohm? so how many watts will I be delivering to each sub? I know I could wire them in a 2-ohm bridge mode, but I sorta like the stereo effect in a 4ohm mode. right now I have my infinty refferences wired in 2ohm and when I turn the volme up it sounds like someone is just thumping or banging on my trunk floor! Is this the kind of bass people preffer? Sorry if this sounds confusing, I am not a newbie but there is still lots that I could learn.
Thanks for the replys.
Old Dec 20, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
That combination of amp an speakers will work fine.
Each speaker is 4 ohm DVC, so wire the coils in parallel inside the box. That makes each speaker act as a 2 ohm one.
Then just hook up each to one channel on the amp.
You will end up w/ 300 RMS to each sub.
Old Dec 20, 2003
Yeah, see I didn't know you could do that. Thanks for the reply, I cant wait until I get them, but I hope I get my cap and my fatmat around the same time so that it can be a 1 day install!
Old Dec 20, 2003
alex053's Avatar
the rockford website has a nice wireing diagram for how to do it all
http://www.rockfordfosgate.com/rftech/wiringwizard
u shoulda got the dual 2 ohm version and my bd1500
VVVVVVVVVVVVVVVVVVVVVVVV
Old Dec 21, 2003
HondaLuver's Avatar
Its a celebration bitches!
that amp wont let the subs reach their full potential....
Old Dec 21, 2003
Well I bought the amp before I decided to buy the subs so I guess I'm screwed until I can find someone to buy it off me.
Any ways, can some one post a diagram of what regular joe ment by wiring them in parallel inside the box to give them a 2 ohm load. If I brigde them, the jl site says that I will dual 4ohm into 1.5 ohms?
Is there an advantage to using both voice coils or am I fine with just one.
A diagram or link to the actual page will help alot, this is the first time I am dealing with DVC subs.
Thanks
Old Dec 21, 2003
alex053's Avatar
check the link in my post. but since u missed it the fist time..here it is again
Old Dec 21, 2003
I guess what has me confused is what to do after I wire them in parallel inside the box, how do I wire them from the box to the amp. Because I am only going to be using one + from speaker terminal from one side the box and the - speaker terminal from the other side of the box.
Old Dec 21, 2003
http://www.rockfordfosgate.com/rftec...=14&image.y=11
this page is confusing. What are the speaker wires leading to, the box speaker terminal or one chanel of the amp?
Old Dec 21, 2003
Regularjoe's Avatar
Run the amp in stereo.
Inside the box hook up both (+) side of the coils to the (+), likewise for both the (-). Do this for both speakers in the box. Then run a single wire from the box to each half of the amp.
Old Dec 21, 2003
Alright since I have some extra time on my hands I'm going to do you guys one better and do a diagram for you, all you have to do is fill in the lines of where every wire should go
AMP
CH1 CH2
SPEAKER BOX
Ter. 1 Ter. 2
SUBWOFFERS
SUB 1 SUB 2
Enjoy, and thanks in advance.
Old Dec 21, 2003
Discard the above post, I guess Im too slow.
Thanks regularjoe. Thats exactly what I needed. I'll go ahead and stop my bitching now.
Old Dec 21, 2003
Regularjoe's Avatar
Just did.
Old Dec 21, 2003
HondaLuver's Avatar
i think it was just explained... blah...
JetsterDajet
52
May 8, 2016 12:11 AM
amrhamed
Sep 21, 2015 02:56 PM
scotchtape
Sep 18, 2015 04:15 PM
bashea
Sep 15, 2015 04:59 AM
rayman009
Sep 12, 2015 08:30 PM
