Speaker popping noise...
Old Dec 17, 2003
reflekt's Avatar
reflekt is an unknown quantity at this point
Exclamation Speaker popping noise...
whats up guys..
i was going to post this in the tech stuff or vehicle problems forums, but i thought probably you guys would know better.
basically, it started with my headunit. I have an Alpine CDA-9815. After i got the hu, i was running stock speakers, and everything was fine and dandy. Then all of a sudden, I started to hear this weird popping distortion type of noise in the rear left speaker. It would only make the pop noise when I might hit a bump, and DEFINITELY when i take sharp turns around a corner. It's almost as if something is bouncing around in my speaker. And there was also a cluttered distortion noise while the music played, like a *CHTSHHH* noise.
sooo....the one thing i could think was...maybe my speaker was blown? I have no idea how that could've happened, but that was my understanding. So, a few days ago, i replaced/upgraded all my speakers, front and back, with alpine type S speakers. After the grueling installation, I bumped the speakers, and they sounded DOPE. and i was all happy cuz i got rid of that stupid distortion and popping noise. BUT, then on a drive home that night, i took one of those tight turns around a corner, and i heard the poppping noise again! i was like....WTF. then that couldn't have been my stock speakers...NOR the brand new alpine speakers.
So now, i'm left with a dilemma and i have no idea what is causing that strange popping noise, along with the distortion. However, on these new alpine speakers...the problem doesnt occur as often at all (the stock speakers did it ALL the time, and I could only listen to my two front speakers by moving the fader up on the HU for that time being). but still, it pissed me off that i spent money on these brand new GOOD speakers, and i still got the problem. does anyone know what might be causing this strange interference/distortion/popping? it's really hard to explain. ANY help is appreciated. thanx!
Old Dec 17, 2003
doubledeuce2k2's Avatar
this noise comes from poor wiring. check the wiring behind the HU. i bet if you jiggled it around the noise would come and go.
since it is just one speaker, it could also be the wiring to that speaker. check in the trunk for any spots in the wiring that look weak or like they might be touching the chassis.
Old Dec 17, 2003
reflekt's Avatar
that actually sounds like that could be it. because..i realized that the popping noise only started to happen after the shop installed my alpine headunit. THEN it started to pop. it's probably some loose wire behind the HU. any other ideas? thanx for the help!
Old Dec 17, 2003
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
check your ground on the HU
Old Dec 17, 2003
WhiteRabbit's Avatar
i might also check yoru trunk torsion bars and struts that hold the rear deck solid.
its a shot in the dark, but if it ony happens on sharp right hand turns, if the rear deck is flexing, then it could be flexing yrou basket, causing voice coil rub.
it might definitely be the cause! try unscrewing the speaker, leave the rear deck off, and try one of those sharp right hand turns, see if it still does it.
Old Dec 17, 2003
tfnaaf's Avatar
BLDNPSI Mod
Nod HU wiring
Old Dec 18, 2003
reflekt's Avatar
thanx for all your guys' help. im definitely gonna pull part the center HU section and check the wiring.
also...today, i was chillin wiht some friends. and while we were driving, every now and then , when we're bumpin the music a bit, and hit a bump in the road...it's go...*pop*...*TCHHSHHH*. but as soon as we literally hit the side of the center HU part...,the right side, next to the HU, it'd go away. haha. so whoever had shotgun, sitting in the front, their job was to hit the side of the HU, whenever it happened. and it's go away. so definitely it seems like its' some wiring business behind the HU, and not something at the rear deck. anyway, yeah. thanx for the help guys!
Old Jan 25, 2004
civicmorph's Avatar
civicmorph is an unknown quantity at this point
my rear Kickers do that once in awhile too, and it's not just one side, it's both but switches sides on the *pop*. I believe it is the RCA cable that I connected it with from my HU, damn 5 dollar cables! I'm just gonna save up and buy monster RCAs for all my amps and speakers, least then I know that won't be an issue causing the problem. Money is of absence right now
Old Jan 25, 2004
The shop you took it to probably did a shotty install. Just pull it out, take off the wire harnesses and solder the connections together. They should have just used a harness replacement anyway so they wouldn't have to splice. Don't know what could have happened back there. Maybe a loose wire touching something.
Old Jan 25, 2004
if it's your rca's, wrap electrical tape around them where they connecr. they may be grounding out on the frame that holds the HU in place. mine make noise if they touch the wrong spot too. and they were like $70.
Old Jan 25, 2004
I've wondered about that. All my RCA connections are open and touching each other and other stuff. Haven't had any noise problems, though.
Old Jan 26, 2004
jttegx's Avatar
OMNES AD UNUM
*i didnt read the thread fully* too lazy
... i have had the same problem with my polk right-front speaker. i thought it was becuz i didnt seal the door panel correctly so water got into it. but its poor wiring becuz i took out the panel n rewired it n now works perfectly.
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Gsxtacy
Sep 12, 2015 01:09 AM
tommycanada
Sep 5, 2015 04:59 PM
