Alpine XM Tuner, Where To Put?
Old Dec 16, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, im getting xm radio at the end of this week and im going to do the install myself since its pretty easy. I am going to put the antenna on the trunk, but I don't know where to put the tuner? The dimensions are 6-13/16"W x 1-7/16"H x 7-7/8"D. The one and only place I was thinking about was under the center console, between the shifer and the dash. Would there be enough room under the center console? If anyone has a better place to put it, let me know. Thanks!
Old Dec 16, 2003
tfnaaf's Avatar
BLDNPSI Mod
Its basically the same size as my black box for my alpine IVA-D900 maybe a bit smaller, and i mounted it in the spare tire well. Should be plenty of room there.
Old Dec 16, 2003
tfnaaf's Avatar
BLDNPSI Mod
Also as i recall the alpine XM box doesn't require power ground it runs off the AI-Net cable yes? so the cable SHOULD be long enough to reach from trunk to deck, but i could be wrong. After all i had to buy an extension cable for my black box!
Old Dec 16, 2003
Rufus's Avatar
If you really need some space, I put the brain for my IVA-D900 in the drivers side quarter panel with the supplied brackets and it bolted right to the existing braces. Outta sight, outta mind....and it's closer than the trunk.
Old Dec 16, 2003
Havok2k1's Avatar
Wicked Pissah Admin
You could always mount it under the drivers seat....
Old Dec 16, 2003
tfnaaf's Avatar
BLDNPSI Mod
I mounted the iva-d900 box in the spare tire well because the amps and bass cube are right there, so it makes the rca cables as short as possible ( see picture below ) . BTW the nos is now hooked up with remote opener Yippeee
But back to xm radio box, the brain could be mounted like he said in the driver side rear quater pannel that way its a little closer to the deck, and the distance to the rear trunk lid isnt realy further away.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
Jeffdp
Aug 5, 2015 11:38 AM
Supramk3
May 11, 2015 07:55 PM
CapYoda
Nov 29, 2001 07:37 PM
