balance issues
Old Dec 13, 2003
dups's Avatar
dups is an unknown quantity at this point
balance issues
I talked to white rabbit a little about my problem and he was very helpful as usual, but I was just curious if anybody else has this problem or am I just crazy. I used to use my stock headunit with infintiy reference 605cs components and never had any problems. Now I've replaced my headunit with the nakamichi cd-400 and for some reason it always sounds like my passenger side speakers sound a lot louder than the drivers side. If I kind of sit in the middle I think it seems ok, but how come I never noticed this problem before? Also is anybody have problems like this and what have you done to balance it out better all around?
Old Dec 13, 2003
madmax's Avatar
madmax is an unknown quantity at this point
my alpine9811 hu have time corection that help alot
Old Dec 13, 2003
dups's Avatar
I love the sound quality of the nakamich, but I'm almost starting to wonder if I should have found one with time correction instead. I didn't know it would be important.
Old Dec 13, 2003
LudlamTheory's Avatar
i boogie for the raindrops
well, 1 question and 1 thing for you to try
1 - is your setup identical to what it was when you were running the stock deck?
2 - record a test tone on a cd, get a multimeter, and read the rca voltage on both the left and the right. it could be a headunit problem.
when i ran speakers in stock locations i would never have teh balance on center. id run it slightly over to teh left.
Old Dec 14, 2003
dups's Avatar
would moving my speakers into kick panels help?
Old Dec 14, 2003
dups's Avatar
Also, I've started thinking about my original setup more, and I think its possible that I might have had the speaker wire running to the line-output converters out of phase. So my front components might have been out of phase with the rear speakers and subs.... hmmmm.....
Old Dec 15, 2003
theres a million possibilities. did you try the voltage checking like i said?
Old Dec 15, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Think about this. You sit in the drivers seat, and no one is sitting in the passenger seat. Your passenger side mid is producing sound and its angled toward the center of the car, which will eventually hit you. The driver side speaker on the other hand is angled towards the center of the car, but you are not in the radius of the sound field, and your left leg is blocking most of the sound.
Solution to the problem....
Cut off your left leg.
Old Dec 15, 2003
dups's Avatar
lol.... I'm not cutting off my left leg for the sake of SQ... not gonna happen. Anybody have any other ideas?
Old Dec 17, 2003
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
dups - I have a 98 sedan with what I believe is faulty stock speaker wiring - I noticed the right passenger speaker was cutting out intermittently a year after we bought it. Having upgraded the head unit and all four speakers, the factory wiring remains the only constant.
Not saying you have a wiring problem, but keep it in mind.
Old Dec 17, 2003
dups's Avatar
yeah, my speakers don't cut out or anything. I'm pretty sure its just me and my position reletive to the rest of the speakers. Its just kind of wierd though because other people I know usually complain about the drivers side sounding louder then the rest. Thanks for the advice though.
Old Dec 18, 2003
coop's Avatar
you would expect the drivers side to sound louder because you're closer to it....
Old Dec 18, 2003
id expect the passenger side to sound better because it has a more direct straight line towards my head, as opposed to teh drivers side, which is a 90 degree tunr from my head (if were talking about sotck locations)
Old Dec 18, 2003
coop's Avatar
Ludlam - it might sound better, but is it LOUDER?
Old Dec 18, 2003
quite possibly so. the farther you go off axis with sound, the more sound you lose
this is of course very very dependant on speakers.
the stock speakers are probably (note i sy probably, meaning i dont know) designed to have a very good off-axis response.
now some speakers are even designed for stock locations as opposed to kickpanels.
take this tweeter for example :
you can see tht on axis, or in a kickpanel or somewhere facing you, the high end peaks way high.
but off to an angle, it sounds much better.
ok, im ranting and getting off course here
final note:
one speaker may be louder than another on or off axis, all depends on its characteristics. as to the speaker farther away sounding louder, it all depends on a combination of the closer speakers off-axis response vs the distance vs the frequency vs etc. etc. etc
you get a speaker that has HORRENDOUS off axis response, and yes, the passenger side will definitely be louder
like this one:
Old Dec 18, 2003
dups's Avatar
so its possible to find good speakers that are balanced when off axis like they are in the stock locations?
Old Dec 18, 2003
yup
certain sets such as the adire audio koda 6.1 component set are designed for stock locations.
Old Dec 19, 2003
doubledeuce2k2's Avatar
my PSD 216 quarts really fill well in near stock locations (tweeters by the door handle).
tylerginevan
Apr 27, 2015 12:29 PM
bo0sT
Apr 3, 2002 09:11 PM
Desi
Mar 16, 2002 06:27 PM
Oishi
Feb 25, 2002 09:53 PM
RickyRocket
Nov 30, 2001 10:14 AM
