amping stocks?
Old Dec 9, 2003
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
amping stocks?
Hey,
I had to sell my components for financial reasons, so I put my stocks back in. I still have a US Acoustics USX2100 lying around. It claims to put out 100w x 2 @ 4 ohms. Will this be too much power for the stocks to handle?
thx in advance
Old Dec 9, 2003
WhiteRabbit's Avatar
yes. way too much
Old Dec 9, 2003
iLLuMiNaTi's Avatar
heh
do you know if this amp really does put out 100w? or is it over/underrated? haven't really had any experiences with US acoustics...
edit:
A friend gave me this amp, and I haven't really hooked it up to anything yet...
Old Dec 9, 2003
i dunno about over or underrated, its not a perfectly clean signal, but hey, neither are my hifonics amplifiers.
my buddy took first at SQ running a US accoustics amp in the pro class this summer! so its capable equipment.
regardless, 15 watts peak versus 100 watts rms? even if they are 8 ohm speakrs, I would think it'd be pushing it
Old Dec 9, 2003
Ed's Avatar
Ed
maybe if the gains were turned all the way down? You can try I suppose, keeping the volume down. I have my stocks amped, but only with about 55 watts rms.
Old Dec 9, 2003
iLLuMiNaTi's Avatar
ed,
do your speakers distort when you turn up the volume?
Old Dec 10, 2003
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
U.S. acoustic makes nice amps for the price and im sure it puts out what its rated at. I had 50 on my stocks in my old 02 vic just while i was waiting for my brother to finish my fiberglass kick panels so they could get painted and it killed the 6x9s and im sure the 6.5 wernt good for to much longer. The stock speakers suck horribly and are only good about 35 watts
Old Dec 10, 2003
LudlamTheory's Avatar
i boogie for the raindrops
what you COULD do9, if you dont care about fading front to rear, is wire the front right with the rear right in series, same with teh other side, and present each channel with an 8 ohm load, 50 watts theoretically, and have 25 watts per speaker... youd have control of left to right, but not front to back
Old Dec 10, 2003
iLLuMiNaTi's Avatar
that seems like a good idea, but I usually set my fader to the front (not all the way but around 6/15ths).. thx though
Old Dec 10, 2003
if you really wanted, you could build a small circuit that limited power to teh rears however much you want
its called an l-pad and it attenuates by increasing resistance. tweeter level adjustments on crossovers are usually just l-pads
Old Dec 10, 2003
Ed's Avatar
Ed
Yeah, my stockies distort when i turn it up really loud, just like any speaker would when it's way overpowered.. I just avoid turning it up that loud.
Old Dec 11, 2003
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
If I remember correctly, aren't the stocks something like 15W or so, to make them sound better with the trickle of power supplied by the stock head unit?
Old Dec 11, 2003
doubledeuce2k2's Avatar
solution: buy my stuff
V
i wouldn't really bother amping them unless you planned on keeping them for a while. or if you want more bass. you might have no speakers before long.
Old Dec 12, 2003
tfnaaf's Avatar
BLDNPSI Mod
General rule of thumb is you can never have too much CLEAN power. Could you blow the speakers with an amp rated almost 7 times more then the speakers? SURE you could. But more likely to blow them with less power that isn't clean.
Old Dec 14, 2003
Lucid484's Avatar
Lucid484 is an unknown quantity at this point
um well I have over 100 watts going into my stock fronts and even with the HU volume maxed they sound great and have no distortion...my gains are turned almost all the way down though...but i'vee been running them with 100watts for over a year and i have my crossover set at 70-80 and they mix smoothly with my sub!
Old Dec 14, 2003
iLLuMiNaTi's Avatar
what kind of amp are you running? also, what kind of crossover??
Old Dec 15, 2003
Lucid484's Avatar
Sony XM-475GSX 4 way amp bridged into 2 way because I took my rear speakers out,using internal crossover.But I also had my Blaupunkt Class T amp running them for a lil bit and that puts about 116rms each speaker but now that is bridged to about 350rms to my sub.
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
