switch door
Old Nov 16, 2003
civic7gen's Avatar
civic7gen is an unknown quantity at this point
switch door
Does anyone knows how the switch works if your open your door ? I looked and I only see a green wire attached to it .
Old Nov 16, 2003
Jaykuai's Avatar
ish...
ah?
Old Nov 16, 2003
LudlamTheory's Avatar
i boogie for the raindrops
all it does is send a - signal when teh switch is not pressed, ie, the door is open
Old Nov 16, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
Re: switch door
HUH?????
Old Nov 17, 2003
ok, for those that are clueless, there is a little button switcher thinger that gets pushed down every time your door closes. if yer curious, next time your door is open look at the little button thinger that makes your interior lights shut off. when that switch is unpushed, it touches the metal of the car, thereby grounding it, thereby turning on the relay which controls the car knowing whether or not the door is closed. when the switch is pushed down, theres plastic around it that insulates is from the body of the car
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 18, 2015 07:37 PM
werdnahall
May 17, 2015 11:37 AM
MamaBear2015
May 3, 2015 02:17 PM
