optima red top?
Old Nov 13, 2003
hkdblackbelt's Avatar
hkdblackbelt is an unknown quantity at this point
optima red top?
i just recently bought a optima red top battery w/ 910 cold crank.
i was having problems with the stock because i have a 1000watt amp pushing my twelves and neon lights all up inside my car aswell as the underbody lights. my batt would die all the time.
my question is will the red top help my problem or should i have gone with a yellow?
the stock batt has like 410 cold crank . i was just wondering if i made a good buy.
Old Nov 13, 2003
PunkingCivic's Avatar
I need TP for my bunghole
it wouldn'y hurt to get one of these
Direct power system
http://streetracing.tiora.net/home.php?op=go&id=853
or here
http://www.directpowersystem.com/
Old Nov 13, 2003
doubledeuce2k2's Avatar
what size did you get? group #? i was thinking about it but they don't list a redtop for civics at last check. how tough was getting it to fit?
Old Nov 13, 2003
WhiteRabbit's Avatar
i dont know anyone ever dissatisfied with a redtop
do you think it would have been worth the extra $30 for the yellow? i dunno...
Old Nov 13, 2003
If you only turn on your accessories when the car is running, you shouldn't drain the battery much. Red tops are supposed to charge faster as well. Yellow is good for bumping the system when the car is off.
robbie374
Jul 7, 2015 02:56 AM
