IPOD install
Old Nov 12, 2003
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
IPOD install
Hi guys,
I wanted to know if it is possible to hook up an IPOD to my car sterio so that I can play MP3 directly from the IPOD through my car system. I have the factory radio.
I have tryed the wireless devices that are meant to do this, but the sound quality sucks, Maybe there is a way to addapt a plug to my radio somehow so I can just plug it into the ipod.
Thanks !
Old Nov 13, 2003
dups's Avatar
dups is an unknown quantity at this point
There is an adapter that will plug into the back where you would hook up a CD changer. It basically will turn it into an auxillary input. Its a special adapter though and its hard to find. I'll try to see if I can find the website link I had that was for this.
Old Nov 13, 2003
alex053's Avatar
Install Edge makes an FM modulator..so do alot of other companies....makes it so you tune to 87.1 on your fm dial and can play an aux source thru the radio.
Old Nov 13, 2003
dups's Avatar
This looks like it is exactly what you're looking for!
http://www.ben-johnson.org/blog/inde...&more=1#more37
Old Nov 13, 2003
Profoxcg's Avatar
dups,
Ur the man !
Thanks,
Alex, I have a belking modulator and the original iTrip and both are horrible.
Old Nov 13, 2003
benjohnson's Avatar
benjohnson is an unknown quantity at this point
I was wondering when my site would be discovered by a Civic board...
Anyways, almost all of the details you need to know are over on my site. In hindsight, I probably would have routed the RCA cabling around the passenger side of the console instead of coming through the top of the storage pocket.
The audio quality is much better than either an FM transmitter, modulator, or cassette adapter.
If you're looking for details on other car installs, the forums over at http://www.ipodlounge.com would be a good place to go.
--Ben
Old Nov 13, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
You can add the AUX inputs, but it is only available for certain brands of HU. I found mine for Kenwood at Ultimate Electronics ($19.99) and they also had Alpine. Is there one for the stock HU?
Old Nov 13, 2003
Profoxcg's Avatar
yeah if you have an after market radio then it is much easier and chaper.
While using the FM modulators it does like I am listening to some really bad AM station alot of times. I should've know better
Old Nov 13, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I sent the diy to the webmaster so it can be added to the audio diy section
Old Nov 13, 2003
dups's Avatar
It is cheaper to add to an aftermarket headunit, but you have to spend the money on an aftermarket headunit. Its not a bad deal to follow his DIY to add an Auxillary input to the Stock headunit
Old Apr 4, 2004
jayrck81's Avatar
rocking the dx w/ vtec
jayrck81 is an unknown quantity at this point
I just got the iTrip for my iPod, it f@!#ing blows, it gives the worst signal I have ever heard. Wish I did a little research before I bought it. I hope that the place I bought it will let me return. I would advise not getting an FM Transmitter if you have an iPod, use an aux input instead.
Old Apr 4, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I haven't heard much positive at all about FM modulators. Luckily my Alpine deck has an aux in via the AI-NET cable...
Old Aug 11, 2004
jugadro's Avatar
jugadro is an unknown quantity at this point
P.I.E. (precision interface electronics) makes the aux adapters that are sold pretty much everywhere - you can see/buy them directly from them - http://www.pie.net/1virtual.htm - but i'd shop around. here's some others too:
http://www.installer.com/ipod/index.html
http://www.logjamelectronics.com/acurahonda.html
http://www.rtgelectronics.com/cgi-lo..._harnesses.htm
Old Aug 13, 2004
sirlan's Avatar
sirlan is an unknown quantity at this point
I just installed an aux connection for my iPod to my '04 stock stereo and took some pics as I went. I'm not completely finished yet but I have it working.
One problem I've noticed is it skips 3-4 times if I change songs using the stereo controls instead of the iPod controls. I hope to get that figured out soon. Other than that, it seems to work well.
I used the PAC aux-pod.
Pics are on the 3rd page of my cardomain site below if anyone is interested.
Old Aug 16, 2004
sttaylor's Avatar
sttaylor is an unknown quantity at this point
I bought a PIE aux adapter which I purchased from cardiscount.com for $56 including shipping. I used the instructions from cheaphondaparts.com for installing a factory tape deck. The total install took me about 3 hours. Of course I could do it alot easier the 2nd time around. I highly recommed this for anyone with an IPOD. Essentially the adapter is a small box with 2 rca jacks & a 14 pin connector which hooks up to the CD Changer input. I simply stuck the aux box behind the center console where the fog light switch would be. I left the right switch cover off & fed the 3 ft. RCA to 1/8" cable. I have an I-trip too & it just doesn't cut it for replacing CD's. FYI I have an 04 EX civic coupe 5sp Magnesium.
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
