Help!
Old Oct 27, 2003
KeNsHiN's Avatar
LEVA
Help!
ok i have 2 15's that rattle the **** out of my car! and it's ok but sometime when i turn it down i hear little rattles everywhere! so i ask is there a spray of somekind that i can use to claim down the rattles?
Old Oct 27, 2003
KeNsHiN's Avatar
LEVA
"walmart.
theres cheap stuff for 2.50 or so a can and theres the stuff made by 3m thats like 4 a can.
the 3m stuff has more density to it"
is this true?
Old Oct 27, 2003
Logan3024's Avatar
Kenshin
Finding rattles is very annoying. Before you start spraying anything, you need to find the rattle. Is there anyway you can turn off the mids and highs, just so the bass is playing?
If you can do that, turn the bass up loud as hell, and find every rattle. somethimes you can get away with stuffing a sock or something like that.
i would recommend you stay away from the foam (liquid foam crap) and save and dynotmat your WHOLE trunk. Not only does dynomat stop your rattles, it also make the ride ALOT quieter if applied correctly. it also adds hella weight. but if you got a system, that shouldnt matter to you anyways.
The rear deck and behind the liscence plate is where my worst rattles came from.
Old Oct 27, 2003
KeNsHiN's Avatar
LEVA
DIZZLE thank you for taking the time to write something so clear and understandable. I will take your advise and do that first thing tuesday morning. I agree the most rattle i get does come from my rear deck and behind the licence plate, is there any thing that helps?
Old Oct 29, 2003
Braydogg's Avatar
Braydogg is an unknown quantity at this point
Yeah I talked to some good audio guys and they have they rides dynomatted out... and its nice... I was thining about doing my trunk and doors soon.....i aint woried about the weight....like Im breaking the sound barrier now lol.... yeah right..... dyno mat extreme works real good!
Old Oct 29, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
I used dynamat in my trunk and front doors.. and I can honestly be the guy to admit to you.. that it makes your ride a lot quieter.. especially with those loud high performance low profile tires we use.
When I get more money and time. I plan to buy more dynamat and continue dynamatting the other parts of the car I missed.
A lot of rattling came from the trunk lid of my car.. THat has been stopped by applying dynamat.. now when you turn it up really loud.. the spoiler (brake) light rattles a bit.
Other than that.. it's good.
My rear deck still rattles.. but that's because the area in the middle by the center brake light on the rear deck is constantly bouncing off the rear windsheild when I pound my bass. I'll probably end up either shoving a sock in there OR I'll shove something underneath and this way it'll be pressed up and I won't have this sock in the rear windshield.
Old Oct 29, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
For my license plate I fatmatted it, then put a 1/4" layer of neoprene foam on it, stops the rattle quite nicely.
Old Oct 29, 2003
KeNsHiN's Avatar
LEVA
^^ i did that too but i have no foam! lol i will look into that
