i have problem with reception
Old Oct 24, 2003
Vezman's Avatar
Vezman is an unknown quantity at this point
i recently purchased a new system for my civc and now i get shitty *** reception from my deck.
i had two jl amps installed. i went back to the car stereo place where i had it done and they said it had to do with the antenna being in the back window and the amps sending off a signal. i was wondering if any one else has had this problem and if so how too correct it
i have a jl 300/4 and a 500/1
i dont think it has anything too do with the amps, but mostl likely i am wrong
Old Oct 24, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
Their is an additional wire you have to connect, I think that it was green and another color, but I will search for you.
Old Oct 24, 2003
4Saris's Avatar
Here is a link to the thread. Read the whole thing.
bad reception
Old Oct 24, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
yeah I think they call it the power antenna lead, I know my wiring harness didnt have that wire so I had to splice into the stock wire.... our antenna must have some sort of booster that needs power to work properly.... I noticed a difference once I connected it right away....
Old Oct 24, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
is the antenna built actually into the glass or applied on top, i was wondering if i could remove it from my window and put an antenna on the roof or somethin.
Old Oct 25, 2003
4Saris's Avatar
It's in the glass, the little amplifier should be in the rear passenger A-pillar, I would say just connect the wire.
cdt12271
Apr 23, 2015 11:36 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
