.5 Ohm Amp?
Old Oct 22, 2003
nongv's Avatar
nongv is an unknown quantity at this point
.5 Ohm Amp?
is there any amp that is stable to .5 ohm?
Old Oct 22, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
ehh. I doubt it. And if there is, you would pay for it through the ***. 1 ohm stable is hard enough. I know this doesn't answer your question, but I'm just curious; why do you need an amp stable to .5 ohm?!
Old Oct 22, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
there are quite a few
Atomic does, some orions, i think us amps made a few. But yea you will pay for them
Old Oct 22, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Course there are.
I think JL amps are 0.5 stable.
Some of the Soundstreams. I think Orion makes some too. Maybe Hifonics too.
Old Oct 22, 2003
fonto's Avatar
The LA Clipper
Some Orions and US Amps.
Old Oct 22, 2003
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
definately orions.
i saw a mustang today, it had an orion amp rated at 50x2 @ 4 ohms, H2250 model or something, what a cheater amp.
the shop tested that thing, put out about 36 volts, then they calculated it, 2600 watts or so, i said "how do you figure that?" he says "multiply 36 by itself, then divide by .5" i was amazed to find it ran at half an ohm. i was also amazed that it was rated at 100 watts, but put out over 2000watts.
so yes, some orion amps will do .5 ohms.
Old Oct 22, 2003
nongv's Avatar
well i was just wondering about it. i probably couldn't afford it. will look into those amp though.
Old Oct 22, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
JL isn't stable that low, i tried with my 500/1 Mono. HiFonics Colossus is stable that low, they just installed one at the local shop i do some work for. Virtual Technologies amps are stable that low. There are bound to be more, but these are the one's i have found from the brands i have available to me. all of them are high dollar too. why do you need them stable that low anyway? planning on making mass amounts of power?
Old Oct 22, 2003
civic01vtec's Avatar
my amp is stable at .5 ohms and runs nice and cool.....XTANT baby !!!
cost me $1,200 for 1000W and i will never buy anything different.
I had (1) 15" sub hittin 150.8 db's off of it.
Old Oct 22, 2003
doubledeuce2k2's Avatar
i have an audiobahn high current that is .5 ohm stable... 1 ohm bridged. and it's not super expensive. it's rated 75rms * 2channels at 4 ohms, do the math... 1200rms total power.
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796
there's your orion amp
as to why you may need an amp stable so low, there are subs which feature 1, .5, or .25 ohm voice coils. it's all about flexibility.
Old Oct 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
the old orion hcca's were .25 ohm stable stereo, .5 ohm stable mono
Old Oct 23, 2003
nongv's Avatar
what kind of audiobahn is it?
Old Oct 23, 2003
Logan3024's Avatar
What sub has a .25 ohm voice coil?
These companys that made amps that can handle less than 1 ohm, made them for competition purposes. For example..................
Most competions back in the day were judged using wattage classes. 1-300, 301-600, 600-900 and 900+, at 4 OHM
A guy could use a 75x2 amp, run it at .5 ohm, and would easily dominate the spl class for the wattage class he was in, trust me you would not want to enter a SQ competition at .25 ohm, THD would be horrible.
Old Oct 23, 2003
there is none......amps that can handle low ohm impedence's are used when using multiple driver set-ups.
Old Oct 23, 2003
fonto's Avatar
The LA Clipper
But you would prolly only want to use subs on this kinda set-up. Imagin if you had 4 sets of speakers to one channel on an amp...how bad would that sound? <<Retorical Question>>
Old Oct 23, 2003
WhiteRabbit's Avatar
the bigger question is, if you are wiring something to .5 ohm, why not jsut wire it to 2 ohms instead and get a different amplifier.
Old Oct 23, 2003
b/c i have seen ppl run 6 subs off of one amp and wired them down to run 1 or .5 ohm's. It all depends on what u want to do. I had (4) 15's running off one amp at 1 ohm and my amp is stable down to .5, i could run more subs (if i had the room).
Old Oct 23, 2003
im just saying i cant think of a single situation where yoru only option is to wire down to .5 ohms as opposed to something higher, is all. for those who are searching for an amplifier, and think they need smoething that is .5 ohm stable, mono.
Old Oct 23, 2003
^^^ right right......today there are so many options out there with amps that i don't even know who makes what anymore. Amps that are stable below 1 ohm are becoming obsolete.
Old Oct 23, 2003
alright, i could have sworn i saw a sub featuring 4 .25 ohm voice coils, but i can't find it a second time so i'll take the hit.
as to the audiobahn amps you asked about, i have a A2350HC that makes...
75RMS * 2 @ 4 ohms
150 * 2 @ 2
300 * 2 @ 1
600 * 2 @ .5
1200 * 1 bridged ar 1 ohm
Old Oct 24, 2003
lets say you find a quad voice coil .25 ohm subwoofer.
wire all in series, thats a 1 ohm load.
one ohm stable amplifier.
industry standard! vtec is right, .5 ohm stable amplifiers are obsolete, imo
Old Oct 24, 2003
[QUOTE]Originally posted by DoubleDeuce2k2
[B]alright, i could have sworn i saw a sub featuring 4 .25 ohm voice coils, but i can't find it a second time so i'll take the hit.
Must have been a custom made sub just for ***** and giggles or was made for spl. Therefore they would put (4) mono amps on it that were stabe at .25 ohms. Stupid IMO.
I did see on the internet a custom made sub that was 6ft in diameter.
Old Oct 24, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
You could look into TRU amps, they are .5 ohm stable
Tedverseti
Apr 23, 2020 01:45 PM
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Mc7602
Sep 17, 2015 02:01 PM
