what kind of wire to use between sub and box
Old Oct 20, 2003
exedotbat's Avatar
exedotbat is an unknown quantity at this point
what the title says. I have a roll of this wire is it ok to use between the sub and box
it says "moster x1 compact precision stranded high resolution speaker cable with magnetic flux tube and lpe dielectric 13" on it
Old Oct 20, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
i'd say so. In all honesty, I've heard a lot of sound systems, and the wiring really doesnt make that big of a difference...especially with subs. They're just booming anyway, not much sound quality to be lost. I just ran some cable I had laying around the house, and it works fine.
Old Oct 20, 2003
jwalker87's Avatar
Bodacious Member
also, if you look at the wires going to your stock speakers, they're I think 24 gauge......tiiiiiny. So if you're splicing off of those to get a signal to the subs (like I did), then that's your bottleneck right there, so there's really no use using higher cable much anywhere else.
Old Oct 20, 2003
exedotbat's Avatar
No i just want to know if the wire is ok to use inside of the box to connect the sub to the connectors on the box.
Old Oct 21, 2003
WhiteRabbit's Avatar
sound slike 13 gauge, plenty fine. 16 guage would be the minimum id use
danace99
23
Jun 28, 2015 08:49 AM
Lopes101
Jun 7, 2015 08:04 PM
Shabba
May 13, 2015 10:55 PM
tkcne
Apr 18, 2015 02:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
