sub box wood
Old Oct 9, 2003
blue03civic's Avatar
Pro Skater
sub box wood
neone kno wut type of wood a sub box is made out of...and where can i get it?
thanx
Old Oct 9, 2003
civic01vtec's Avatar
the best is 3/4 MDF......ur local lumber yard will have it, but it is expensive. U can got the cheap way and use particle board, it is not recommended, but there is nothing wrong with it, unless it gets rained on.....lol
Old Oct 9, 2003
cardboard and duct tape.
Old Oct 9, 2003
^^^^ lol........i have heard many spl records were broken with the wonders of duct tape......i think it's in the glue that is on it or sumtin.
Old Oct 9, 2003
use 3/4 in. particle board or MDF, use drywall screws (1 1/2 in) about 3 inches apart, use braces inside box, use liquid nails to adhere panels together, use liquid nails on the edges inside the box and take ur finger and glide it along the edges to make it completely air tight and smear some liquid nails overtop each screw in the box. Anymore questions, then PM me. I've built approximately 30 boxes in my life, which isn't alot to some but is 30 times more than others have.
Old Oct 9, 2003
Pro Skater
haha its ight its funny haha yea that helps thanx a lot guys
Old Oct 9, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
1/2" or 3/4" MDF board. You can get it for like $8.00 per sheet (4'X8')
Old Oct 9, 2003
LudlamTheory's Avatar
i boogie for the raindrops
dont use anything below 3/4" MDF wood... dont touch particleboard
there are other more rigid and lighter woods, but theyre MUCH more expensive
Old Oct 10, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
3/4" MDF is standard for boxes. Use lots of screws and no matter what you use glue any seals etc... Actually the glue will hold more than the screws if done right ....
Particle board is a big no no. It's just not rigid enough. Sounds like ***. I tried to use it once in a pince when I ran out of MDF. Man was I pissed. Sounded like *** and since I glued it I couldn't get it off. Only solution was to start completely over. It was worth it though. Sounded so much better.
Personally I like these laminated pine boards Lowes sells. You can get up to a 1"x16" (5/8" x 15.5" actual). Really nice to work with. Worked great for my two JL 8w3's last weekend.
I'd love to try a box out of like 2" oak planks. Now that would be a box baby.
Old Oct 10, 2003
ehh... you can use 1/2" MDF and be fine, depending on how you finish it. I have a box made of 1/2", which was built by a sub company and it works great. but, and this is the big factor i think, it is finished with spray-in bedliner (Rhino Linings).
Old Oct 13, 2003
Deceit's Avatar
Deceit is an unknown quantity at this point
CARBON FIBER
Old Oct 14, 2003
alex053's Avatar
13 ply birch owns all. only around $100 a sheet. never use particle board...its to porus (leaks like a ****)
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
General DIY
Sep 25, 2015 08:02 PM
