Advice/Opinion....
Advice/Opinion....
Hey everybody, I was just down lookin at a system and i wanted your guys opinion on this setup, in an 03 ex coupe....
2 Rockford 10" HE's
in a Bandpass, 4 port (i think theyre called ports!) box
150 bucks
powered by a monoblock Rockford 300 watt amp, forgot which one, priced at $250
2 Rockford 10" HE's
150 bucks
on th..e subs.
while the price is right, the sound may not be that good. a good bandpass does rock, but odds are it isn;t that swell. see if you can have a trial listen before you buy.
on the amp... big ***
. for that money you could almost buy a kilowatt of power new, let alone a 300 watt used amp.
Rockford used to make good amps but not anymore. Their subs are about the same. Sounds like this guy is a big rockford fan. I would go out and listen to what's available and pick what you think sounds the best. Personally I don't like anything made by Rockford.
