14 volts
Old Oct 1, 2003
aj5601's Avatar
aj5601 is an unknown quantity at this point
14 volts
OK, I know to get 12 volts to your amp you just hook it up.... Simple enough, but how do you get the 14 volts? I keep seeing amps that of course push more power at 14. Anyone know how to get this extra power to the amp?
Old Oct 1, 2003
alex053's Avatar
alternator.
Old Oct 1, 2003
formulad97's Avatar
formulad97 is an unknown quantity at this point
Turn the car on
Old Oct 1, 2003
CivicSouldjaEX's Avatar
^ ha ha
Old Oct 1, 2003
justplainbad's Avatar
Victory is Mine!
justplainbad is on a distinguished road
Re: 14 volts
Typically a car at rest has a battery that stays at 14 volts, but as soon as you turn on the car's engine, the electrical charging system ups the volts to high 13s/low 14s. As long as you make your battery connection from the amp to the car battery with big enough power wire, your amp should be seeing somewhere around 13-14 volts when the car is on. Honestly, even if you put 4 batteries in a car, it will be the same thing...
If you don't believe me use a Multimeter set on DC current and test the car battery's + and - posts with the car off, and then the engine on.
Old Oct 1, 2003
LudlamTheory's Avatar
i boogie for the raindrops
nope... batteries at rest read between 12.6 and 12.66 volts
in order to charge a battery one must have a charge with a higher vooltage going to it, therefore the 14.4 volt alternator...
problem is that accessories running drain teh voltage of the alternator between 12.55 and 14.4 depending on conditions.
Old Oct 3, 2003
Victory is Mine!
Heh, yeah, I didnt mean rest at 14 volts, I meant 12, my bad.
Old Oct 3, 2003
alex053's Avatar
ludlam is a little more wordy than i am i guess..lol the only thing that makes power in a system is the alternator.
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
JetsterDajet
Aug 16, 2015 01:56 PM
jnissen
Aug 9, 2015 05:34 PM
