box enclosure
Old Sep 23, 2003
blue03civic's Avatar
Pro Skater
box enclosure
does it matter how close the back of the sub itself is to the back of the box because the box i have now has like 6 inches of room after the sub and i want to create a new box but smaller and stealthire so if i made it like 3inches closer to the back would that affect the sound or wat?
Old Sep 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
there should be some space, but 3 inches is fine... as long as the back isnt resting on a piece of wood... the coils need to vent...
as to you changing the box size, are you gonna make is less deep and wider? or are you just gonna change the airspace altogether... what subs are you using, and what airspace are you gonna use?
Old Sep 24, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Just go to your local stereo shop and ask them to build you a box via the Thiele-Small Parameters that mach your subs. It will cost a little bit more but it will sound a TON better.
Old Sep 24, 2003
Pro Skater
ludlman, i have 2 12" rockfords and a huge box haha u can see it under my ride what i want to do is juct shorten the boc in the back like bring the back closer to the sub and split it so i can sepearte on each side mostly just to make me more space and get rid of that bhuge annoying box..does that make sense?...
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
h4ldol
Sep 17, 2015 01:25 PM
