indash dvd player and security?
Old Sep 16, 2003
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
i wanna get one of them indash dvd player.. but just afraid of getting it jacked. Since i can't take the faceplate or anything.... i'm just really afraid i might get it jacked.... those of you who have a indash dvd player how do you guys handle this problem?
Old Sep 16, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
I did the hidden HU DIY (see stereo relocation thread started by madmax for more info) that uses your OEM stereo's modified faceplate to cover your aftermarket HU/indash, so thieves see a stock stereo when in fact, behind it is your HU/indash. Then again I also have a detachable faceplate too. Definitely do this DIY, since our cars are so easy to jack our radio.
Old Sep 22, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Simple. Don't get an indash one. Get an external cd/dvd/mp3 player and then buy a monitor (whatever size)... relocate the climate controls, the AC button, the rear defrost button, and the outside/inside air button, then fabricate a whole new dash piece out of fiberglass, abs plastic, carbon fiber, or whatever with a cool sliding cover over the dvd player mounting location and do the same for the screen..
ha, I just kinda pulled that outta my @$$ but it sounds like it'd be a cool idea.. hmmm maybe someday?
Old Sep 23, 2003
Connie's Avatar
With the Hidden HU, that would not really work with a DVD player with flipout screen, I have one and I also have a nice alarm with a pager. I just take the half of the face off that I can and then set my alarm, I also have my windows pretty tinted so you would have to look hard to see much. I have not had a single problem with it yet. Oh, and I also hooked up my Triple air horn to my alarm
Old Sep 23, 2003
HondaLuver's Avatar
Its a celebration bitches!
dam connie, that is a good *** freaking idea. im goin to hook up a triple air horn, im always worried that someone is going to jack my pop up dvd player...
i gots a pop up lcd. the kenwood kvt-910. i really like it, just don't show it off too much when you are going to park somewhere
Old Sep 23, 2003
NorrinRadd's Avatar
Actually... it does work. I have a flipout indash cd/dvd player and successfully did the hidden HU diy w/ no problems. You just need to mount the indash a little further back into the stock din brackets and sand the stock faceplate down even more. I don't have pics yet, but I'll post them later, so you can get an idea of what I'm talking about. This will work regardless if it's a flipout, indash, detachable faceplate (or not), just takes a little more effort (very easy though).
Old Sep 23, 2003
NorrinRadd's Avatar
Ok, as promised here are pics to show that the hidden HU DIY can be done w/ an indash lcd flipout...
Pic to show how far back indash is in stock din brackets.
Just cut and sand the switches, holders, clips etc. behind the stock faceplate for a good fit.
See, still fits flush, even with an indash lcd flipout behind it.
In this pic, notice how close the flip out gets to touching dash. When doing this DIY you'll have to play around w/ the indash to make sure the screen can come out by angling (sp?) the indash up or down, forward or back.
Old Sep 24, 2003
Connie's Avatar
Mad Props NorrinRadd, that is a sweet DIY job...I think it is good enough for a DIY. I posted pics of my player and such on my member rides profile if you wanna look. Linky
PS. Now I have 666 Posts....hahaha
Old Sep 24, 2003
jkim1978's Avatar
hey connie... is your dvd player the only dvd in dash player that has the detachable face feature?... and is that detachable face just like a detachable headunit...? where its not possible to turn on the headunit if you detach it.. and stuff like that.... also.... does your dvd player include tv module... the thing where it lets you watch tv... or do you have to buy that separately????
Old Sep 24, 2003
NorrinRadd's Avatar
There are a lot of indash players that have detachable faceplates. If you look at the pics I posted you'll see that my Pioneer indash has a detachable HU like Connie's Clarion. All the features you mentioned as well are pretty much standard fare these days.
Old Sep 25, 2003
Connie's Avatar
With mine it comes with a lot of stuff like touch screen that is fully motorized and it is 7" (the biggest) but the detachable is half of the face comes off below where the screen comes out and it won't turn on or function or anything without that peice attached. And the TV tuner is seperate, I think the KVT911DVD is the only one that65 come WITH the TV tuner already, but it only has a 6.5" face and it is not touch screen and it is also about 2-300 dollars more last time I checked....
Old Apr 5, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
Sweet DIY! I most do this!
Old Apr 5, 2004
draganjr's Avatar
NorrinRadd - did you use an HU install Kit or did you use the OEM stuff? Thank you
Old Apr 5, 2004
Connie's Avatar
You know how old this thread is? I think he used the HU install kit for the HU and then just used mearly a shaved OEM faceplate to cover it. Otherwise the HU would never get in and stay in in the first place.
Old Apr 5, 2004
draganjr's Avatar
yes i do and does that matter how old it is? and thank you.
would you happen to know the part number?
Old Apr 5, 2004
Connie's Avatar
for what thing. If it is for the HU bracket it probably depends on the make and model. You could probably find the part number on www.crutchfield.com they have all of that stuff. but you stock face comes with the car. he just shaved off the back so it would fit over his new face.
Old Apr 5, 2004
NorrinRadd's Avatar
Nope, I didn't use a HU install kit, just used the OEM brackets, since with the HU install kit it was too difficult (or didn't allow it, can't remember) to slide the deck forward and back. I have since had to weld a metal support bar to the main center console bracket and velcro it to the bottom of the deck to ensure it doesn't move. This because only 2 screws (front) line up with my Pioneer deck and the OEM brackets vs. 4 (front & back), so after awhile the deck would tilt, especially after hitting major dips and bumps in the road. So just to make things clear on what I did... two major ones was to 1) Use OEM brackets and slide deck back (further in) and 2) Shave down back of OEM face. Hope this helps you, just PM me if you have more questions.
Old Apr 14, 2004
allstarsardar1's Avatar
allstarsardar1 is an unknown quantity at this point
dude thats an awesome idea...i think i may wanna do that myself
Old Dec 15, 2004
PunkingCivic's Avatar
I need TP for my bunghole
nice!
Old Dec 15, 2004
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
hmm, i have to try this
Old Dec 15, 2004
Mialifter75's Avatar
Mialifter75 is an unknown quantity at this point
just take it off every night and bring it upstairs with u
Old Jun 23, 2005
draganjr's Avatar
Gravedigger!
Here goes mine:
Pretty easy!
Old Jun 23, 2005
es2k2's Avatar
Proud to be a civic owner
very nice trick!
Old Jun 24, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
Really Old!!!!!!!!
Old Jun 24, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
old thread, just isnt good for those of us who did the deck flip flop. Stock radio wont fit over the bottom slot, and pop out lcd's block the heat vents
h4ldol
Apr 24, 2017 08:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
