3 shivas vs 1 brahma
Im pretty sure that im going to get the the hifonics brutus 1500 amp, because that seems to give me the most bang for my buck. I installed a whole bulk pack of dynamat and i have a optima in the trunk, nice and clean, ready to kick butt. My question is, what are advantages / disadvantages of running 3 shiva 12" vs 1 brahma 12". In terms of SQ and SPL which do you guys think will be the winner. Trunk space is only limited for me in one aspect, will the box fit? I hope i can get this to sound like a 12w7, If I can that would be awsome.
ANY SUGGESTIONS WILL BE HELPFUL
thanks guys (and girls :P)
Electric Boogaloo...
by bulk pack, do you mean the 6 roll case of dynamat xtreme? if so, was it enough to cover your entire trunk? i couldn't get mine to stretch enough to do much more than the trunk floor, and about 1/4 of the way up the sides.
The LA Clipper
Originally posted by LudlamTheory
3 ported shivas?
goooood luck
id reccomend at LEAST 2 cubic feet per woofer to get em sounding decent.. realistically youd want 3 cubic feet
3 ported shivas?
goooood luck
The LA Clipper
Originally posted by Alex053
ya fonto but you have the cone area and box size of 2 if your running iso
thanks guys, i think i will go with 1 brahma, hopefully it will sound pimp.
btw, PopcornPlaya, i forgot to mention that I already had a trunk that I used, i used a bulk pack on top of that. Now when im ready install components ill be all set.
Yes, it's an Acura EL
Brahma 15!!! I have one, and after the box is installed I have just enough room in my trunk to fit a body (OK you may have to use a crowbar) or more often, two record crates. It pounds so hard I'm sure I've lost some hearing.
