How to mount an amp?
Old Sep 11, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
I was interested in putting an amp in my car.....Preferrably under the passenger seat.
How do I mount it? I'm scared to drill into the floor of the car, I don't want to hit anything. How is it done?
Old Sep 11, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Under the seats is really a bad spot, you have the problem of passengers kicking it, and in NY, snow, sand, lots of moisture....
Trunk is a much better spot. You could get creative and put it on the back of the front seats, but since this is your first install thats probably beyond your skill set.
Old Sep 11, 2003
greggdogg's Avatar
Where would you suggest I mount it? I frequently pack my trunk COMPLETELY FULL and I don't want it to catch fire/overheat/etc. Thanks!
Edit: I took a look at this thread , but I'm curious if the amp would overheat in a full trunk. Maybe I could rig a giant switch to turn the amp off and use the stock speaker wires whenever thr trunk is full (not bloody likely).
Other than the mounting, I have concerns with getting power to the amp. How do I get the wire to the battery? Will the neato little battery cover still fit? How do I wire the fuse? I'm a n00b.
Old Sep 11, 2003
GreenNVicious's Avatar
Newbie
back of the fold down seats
Old Sep 11, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Look at my pics, I have never had a problem w/ mine. When I go to visit my parents the back seats and truck are always packed full, so the seats are up. Its about a 4 hr ride ....
I keep the seats up 75% of the time anyway. I put them up whenever I lock the car, and generally forget to put them back down.
Old Sep 11, 2003
Mystic3030's Avatar
If you have never done anything like this before, then I would suggest going to a shop and having everything installed. If you are still intent on doing it yourself, check the DIY section, and this forum. There is tons of information to be found with a little searching!
Old Sep 11, 2003
greggdogg's Avatar
Regularjoe: Where can I view your pics? There's nothing in "My Ride".
Old Sep 11, 2003
Regularjoe's Avatar
Do quick reply's omit my signature w/ my website in it?
I guess so ....
I edited my profile to include my website link too ....
Old Sep 16, 2003
greggdogg's Avatar
How bad/hard would it be to mount the amp on the underside of the rear deck?
Old Sep 16, 2003
Regularjoe's Avatar
You would have to be creative. The torsion bars for the trunk lid are going to be the main issue.
Old Sep 16, 2003
Mystic3030's Avatar
And you would also have to make sure it's very very secure...dont want to hit a big bump somewhere and have it come crashing down. It would be relatively easy to do though...just have to take the torsion bars out, lagbolt some MDF to the crossmembers on the underside of the rear deck, run wires, and attach the amp with a bolt and nut combination...not a screw.
Old Sep 16, 2003
greggdogg's Avatar
What do the torsion bars do, and what happens if I take them out? Any ideas where else I can mount the amp without having it getting in the way? Back of the seat is a no-go because I constantly fold them down.
Old Sep 16, 2003
Mystic3030's Avatar
The torsion bars are what make the trunk lid open/hold it up when you open it.
Old Sep 18, 2003
Havok2k1's Avatar
Wicked Pissah Admin
Make a board for the side of the trunk, carpet it, and mount it there... It will be out of the way and won't have a heat issue...
Old Sep 20, 2003
SMBFC's Avatar
SMBFC is an unknown quantity at this point
I put mine on a board, then put it between the spare tire and the back of the car, out of sight, enough clearence, easy to hide wires, good to go!
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
redcloud
Sep 7, 2015 01:45 PM
