would this work????
Old Aug 15, 2003
DoYung's Avatar
DoYung is an unknown quantity at this point
would this work????
could I run two JL Audio W0 10" 4 ohm each to a power acoustik gothic series 400 watt amp...would it work it says the power acoustik runs 210 rms at 4 ohm...i don't get the ohm **** so could someone explain
Old Aug 17, 2003
DoYung's Avatar
come on with 9 views can't someone help me out
Old Aug 17, 2003
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
i'm not positive about this, but i think you can only wire those subs for a 2 ohm or 8 ohm load, what kind of power does that amp put out at 2 ohms?
for those subs, you would want an amp that does around 250 watts at 2 ohms.
Old Aug 17, 2003
Ed's Avatar
Ed
the W0s in parallel = 2 ohm, series = 8 ohm, can't get the 4 ohms mono the amp wants. not as far as i know
<edit> beat me to it
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
