amp. fuse
Old Aug 10, 2003
toyzSi's Avatar
toyzSi is an unknown quantity at this point
amp. fuse
hi guys,
i need help with my installation..... im running a rockford amp 200rms and a 12 inch rockford sub... my quest is what fuse should i use... the amp came with a 15 amp fuse while the 8 gauge wiring kit came with a 60 amp fuse.. would it be ok to go with the one that came with the kit or do i have to go with the one that came with the amp.... i just want to make sure b4 i fire it up....
thanks for the quick response!
Old Aug 10, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
Generally it needs to be equal to or greater than what is in the amplifier.
60 amp is fine
The idea is that if something happens to the wire between the battery and the amplifier that it will blow. The fuse in the amplifier protects the amplifier itself.
My brother tested his once when he ran the power wire too close the the e-brake pedal in his truck. The install went fine and then the first time he goes to put on the e-brake, as it moved it cut the casing on the power wire. Instant sparks and it kicked the fuse. Without that fuse it would have kept arcing and shorting. Probably would have set the whole thing on fire.
So 60 amp is fine, and put it as close to the battery as possible. Within 1 ft is best.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Mc7602
Sep 17, 2015 02:01 PM
h4ldol
Sep 17, 2015 01:25 PM
Gsxtacy
Sep 12, 2015 01:09 AM
