what amp???
Old Aug 10, 2003
JRS1civic's Avatar
JRS1civic is an unknown quantity at this point
Question what amp???
i have 2 JL audio W3D2 12' subs. i dunno what amp to get for it. i want it to bump hella loud but not to spend too much money. any suggestions? i forgot what the subs rms is, but i know that they are 2 ohms.
Old Aug 10, 2003
alex053's Avatar
Re: what amp???
thats one of the most important parts. find out what it is for the sub, multiply by 2 and find an amp from a reputable company that will put that out rms.
Old Aug 10, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
If they are the original W3's then the RMS is 250, if they are the W3v2 then the RMS is 300. Either way, look for an amp that does 500-600 watts RMS. W3's dont like too much over their RMS power (I know from experience). And they WILL slam with 500 watts even if it's the v2.
Old Aug 11, 2003
LudlamTheory's Avatar
i boogie for the raindrops
basically you need an amp that will do 500 rms at 2 ohms...
what budget are you looking at?
Old Aug 11, 2003
JRS1civic's Avatar
i don't want to spend too much, i just want to get a good amp that won't blow and will still make my subs bump. what amp do you guys suggest? also will i need anything else like a cap or any other stuff? oh and what kind of box or enclosure do you guys suggest for these subs
Old Aug 11, 2003
targetpractice's Avatar
targetpractice is an unknown quantity at this point
I would recommend either a Rockford 500DB,around into a 2ohm load. Great amps, used a 100DB to power 3 JL 12W6's with no problem and you can find them around for about 300 bucks. The other choice I would suggest would be an Orion HCCA series, probably a 250, The nice thing about the HCCAs is that its 1ohm stable in a mono loadand at a 1ohm load it will put out 800 watts RMS.
If you really wanted more power then you can get the Rockford 1001DB amp for a nice 1000 watts RMS at a 2ohm load. Dont worry about dropping the ohmage too much the Fosgates can handle a 1ohm load, no matter what they say, you just have to make sure its in a good spot with air flow to keep it cool
Old Aug 11, 2003
GreenNVicious's Avatar
Newbie
Rockford's are garbage, dont bother wasting your time or money. Get a Phoenix Gold or JL amp. That's the way to go.
Old Aug 11, 2003
Rockfords are great amps. PG, please I have seen soo many of those smoke and melt when trying to push subs. I never once had a problem with my RF amp pushing my W6's. RF will give you raw power to push those subs. Example, 3 12 W6's in a ported box in the back of my explorer and one RF 1000BD amp = 157.8 with amp about 3/4 turned up. Wired down to a 1.5ohm load. I'd like to see a PG amp do that. JL amps are nice though, just over priced
Old Aug 11, 2003
Newbie
You're right, Phoenix Gold amps are garbage, they wont get you anymore. They smoke and melt too much. Oh oops, what's this? I think I was using a phoenix gold amp to power my 2 JL 10W3s, and what was the outcome? Thank you! Next time quit looking through the Best Buy ads for good selling amps, the best amps come from audio shops, and the best advice comes from people who actually know what they're talking about. Thank you!
EDIT: July 2003, Extreme Autofest, IASCA Sound Off
BTW: My box was still sealed too, not even ported.
Old Aug 11, 2003
Newbie
Example of a JL powered system, here's my friends car, same thing: Extreme Autofest 7/03: IASCA Sound Off:
1 JL 12W3v2 in a ported box powered by a JL amp
Old Aug 11, 2003
Little Boy,
If you only knew that best buy sucks major ****. Thats great that you have had great luck with your PG, personally I dont like them, My friends have cooked them many times over trying to drop it to a 1ohm load mono, which sadly those amps are not meant to handle, they just arent. Just curious what are you hitting? You better be able to back it up with a cert too, none of this " Oh I'm louder then that" crap I do see that its an ISACA comp, I have been to a few over here on the East coast. Also been to many of the DBdrags, most recently I won the Kenwood sponsored BD drag held at World Wide Strereo in Montgomeryville, PA in the 1000 watt and under class, with a rockford amp. Please next time you want to try and insult make sure I know nothing about car audio, I have been doing this for about 9 years now. I know plenty
Old Aug 11, 2003
Newbie
Cooking amps just goes to show that 1) you dont have the knowledge to know what your system CAN and CANNOT take, and 2) you have horrible skills at doing an install job OR 3) you actually PAID somebody to do your install job (which is a no-no). 9 years knowing about audio and you suggest Rockford? Wow! I knew to stay away from Rockford having about 9 days of experience with audio. I'm not here to argue, nor am I going to waste my time. Everybody has their own opinion, I was just merely showing that every1 has their own opinion, and showing that PG amps are underrated if anything.
EDIT: BTW, who you callin little boy? Seems like the n00bs with 7 posts are always trying to show up the Big Dogs. Welcome to 2k1civic, kid.
Old Aug 11, 2003
Steve,
I'm not here to argue with you or anything bro. First off yes I am a n00b to this site, cant hide that fact. Second off, Any amp should be able to handle a 1 Ohm load with the proper cool and tuned correctly ( ie not pushing it too hard ) Third, I know how to install my stereo, I think its kind funny you should say that when you have a pre-made JL box for your, Afraid to add a little custom to your setup? Fourth, I would never pay some clown to do my car stereo install, me and my buddy spend a week setting up my trunk to fit my 4 10's and my two amps, yes it can be done in the back of a vic. Before you even start on me about the explorer, It was only a lease and had to be traded back in and sadly a 6 cubic foot box would not have fit in the back of a vic so that had to go as well, but was replaced with 4 subs now. Again I'm not trying to argue, he asked, I answered. Also I never said anything bad about JL amps or anything, nice amps but for a 1000/1 amp its like 600 bucks
Old Aug 11, 2003
Ok, just to get back on topic here. You can pretty much pick which ever amp you want. We gave you some suggestions and everything, Let know which route you pick and how everything sounds
Old Aug 11, 2003
Newbie
All right, we'll bury the beef.
Back to the topic, you should go to your local audio store and check them out. Well, if you already have the wiring for your amp installed, places most of the time (at least this is what i did), plug and played with different amps, and see what the best was. The best they have there is never always the best you can get, i learned that the hard way. You're the only who's going to have to system and you're the one that's gonna be listening to it, get what you like, just take suggestions into considerations, but dont necessarily act on them.
Old Aug 11, 2003
you wont need a cap under any circumstances with any car audio install ever.
for box, i'd keep it sealed.
as to the amp not blowing, an amp blows because of human stupidity, not because of amp quality.
Old Aug 11, 2003
Originally posted by targetpractice
Steve,
6 cf box wouldnt fit in your car?
i had a 6.2 cf box for 3 12's
Old Aug 11, 2003
It wouldnt fit with the amp rack I built for my car. I also wanted some use of my trunk
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
