Hyper voltage system
Old Jul 29, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I just came across this:
http://www.optauto.com/webstore/prod...tion=&back=yes
Now with everyone grounding their engines everywhere thinking it might help something, this might actually do something! Lets get a serious discussion going and see if it might work on our cars...
Old Jul 29, 2003
player's Avatar
from what i understand, that looks like a capacitor, it should be a good idea, but for that price, i dunno
Old Jul 29, 2003
IDQcivic's Avatar
yeah... i was kinda thinking the same thing.. .I gotta find the company that makes it and see if they have any more info on it....
Old Jul 29, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
looks kinda like an ignition module.....pretty cool....needs test results
Old Mar 6, 2004
Bump. I'm interested in getting this. Does it seem like it would work?
Old Mar 6, 2004
Okay thanks. I guess I'll get one and tell you how it is...
Old Mar 6, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
GO GEARBOX!!! WRITE UP REVIEW!!
Old Mar 6, 2004
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
The model number had the letters SUN and it says HYPER in tyhe name. Must be Hyperground by Sun Auto or whatever it's called. Damn i'm smart! ha ha
Old Mar 6, 2004
Yeah, it's the SUN hypervoltage system (not ground wires). Anyway, should be a simple install. I'm getting the MR (multi-rev) version, which is more expensive but should provide better performance at all rpms. There are cheaper versions for just low (torque) or just high (hp) rpm driving.
Old Mar 6, 2004
pheaton's Avatar
A descendant of 2k1civic.com
Sweet gearbox. . I'm looking forward to the review!
Old Mar 6, 2004
opto_isolator's Avatar
I'd like to take one apart and see if its worth $170. I tried to do a little research about it on the net. Its made by Sun Automotive (as was pointed out earlier). Another web site said that it contained capacitors which are supposed to smooth out the transient voltages. It mounts in parallel with your battery.
I can sort of see how it works - I mean, if you have more voltage / current to spare than there will be more for the spark. However it really can't "boost" voltage, only maintain it (at whatever your alternator puts out, say 14.4v). This to me seems a little iffy. I believe it will work, but I'm not sure if its worth the cost.
The grounding kits actually do work. They are the best bang for the buck (as well as changing out all of the positive wires as well).
Old Mar 7, 2004
I have ground wires all going from the negative terminal to tranny, valve cover, and thermostat. But I'll post back results from the HVS. I think it works like a big capacitor to make the voltage flow smooth throughout the system. This can benefit all the systems of your car.
Old Mar 7, 2004
zachgeyer's Avatar
Hummm
Old Mar 7, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
Sounds pretty useful...
Old Mar 7, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
I hate to be a non believer but it looks like it is use less. When your cars are running the alternator puts out around 14.4 volts. The alternator has its own voltage regulator so all the components on the car don’t burn out. Putting this thing in will not give you more torque or HP. Our ignition system more than what our 9.5.1 compression engines will ever need. Our alternators output is more than our electrical system need. The only time you will need capacitor is when you are running a system. If you have system in your car then just get one of those caps for your system. They act like a second battery.
Old Mar 7, 2004
Not to be rude, but caps are never needed and only prevent lights from dimming. They too draw power from the battery. But the rest of what you say makes sense.
I'm trying this because I've seen a dyno that has shown small improvements in hp and torque. I really just want the electrical system to be more stable. It seems like everytime I try to use an accessory, the lights dim or voltage gets cut out. I have a voltmeter, so I see what's going on. I've actually seen that thing BELOW 12V with the car on!
Anyway, yeah I'm just hoping for a constant 14.4V or whatever. The alternator is setup to turn off at certain times when voltage is not needed, but it has done this sometimes with my system and AC on, dropping below the 12V. I had to turn the defrost or rev the engine to make it go back up. This is very bad for electrical components.
This is what they claim to improve on some cars, and here is a dyno (not taking it too seriously).
*Increased torque
*Increased throttle response
*Brighter headlights
*Reduced audio noise
*Improved fuel efficiency
*Longer battery life
Old Mar 10, 2004
§C§H§O§C§O§B§O
i'm just a tad lost, this is the same as a grounding system? so if you get this, you won't need a grounding system like the one that's been sold in the other thread? correct me if i'm wrong, i'm just confused, and the site just confuses me more! >_<
Old Mar 11, 2004
Actually, having a ground kit in combination with this mod will be better. The hyper voltage system is a series of capacitors that stabilizes battery voltage before sending it to the rest of the car components. So a grounding system would be good to have in addition to this.
I should be getting this tomorrow night, so I'll post up some pics and review.
Old Mar 11, 2004
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical forum
Old Mar 11, 2004
LudlamTheory's Avatar
i boogie for the raindrops
that is SO a rebadged capacitor
Old Mar 11, 2004
You're right about that, but it claims to be a series of caps or something. I'll see if I can open it up when it comes. What do you think about it?
Old Mar 11, 2004
a series of small caps is the same thing as one big cap, just cheaper to produce
Old Mar 11, 2004
doubledeuce2k2's Avatar
a SERIES of caps is bad
now a group of caps in PARALLEL is what you want... if you want caps.
but it looks like waste of money. for HP you'd have to dyno tune. and then who knows.
Old Mar 11, 2004
Hmmm...well I finally installed it in the freezing cold. It's working fine and has LED lights that blink. I haven't really driven enough to tell for sure, but the throttle response is definately better and the car just feels like it runs smoother than before. I didn't really notice anything with lights or dimming yet, but we'll see. I'm gonna try it for a while and then post up a review.
There was a dyno done on a honda civic (unknown year) and it showed some hp gain. I'm not gonna just dyno this by itself, though.
Old Mar 11, 2004
WhiteRabbit's Avatar
totally looks like a cap, i agree.
Old Mar 12, 2004
http://www.7thgencivic.com/forums/sh...hreadid=144345
Old Apr 26, 2005
civicferio2002's Avatar
civicferio2002 is an unknown quantity at this point
I have both the Sun Auto Hyperground and Hyper Voltage in my 02 Civic EX and they work great. I got the Hyperground S Type and the Hyper Voltage MR Type and the install and fitment was fine. The cables are pretty unique, lots of shielding and plenty of strands. I noticed that my response was crisper than before, headlights and interior lights were brighter, and most importantly my gas mileage went up. My daily drive sucks, about 60 miles one-way to work, and I was getting about 34-35mpg when averaging about 70mph. After I put on the Hyperground and Hyper Voltage, my mileage went up to 36-37mpg driving at about the same speed! Definately a great buy imho.
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
jzhartman
22
Jul 23, 2015 10:42 PM
