2003 Headunit installation (2003 ONLY not 2001 or 2002 they are not the same)
Old Jul 28, 2003
djuntitled's Avatar
djuntitled is an unknown quantity at this point
obviously this topic is back up for a reason... its because a 2001 civic interior is different from a 2003 civic interior... no one has covered this topic completely...
if u look at the interiors side by side... they are very similiar but they ahve there obvious differences...
so can anyone please give a helping word... for the car's stereo removal (2003 civic)... thanks
Old Jul 28, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
what's different between the 2?
Old Jul 28, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
I just did it for a MT model (my own). It's VERY easy, and goes as follows:
1. Open cup holders, say a small prayer (if a member of a traditional religion. Otherwise, kill a chicken).
2. Remove shift boot from ****, unscrew. If it's an AT model, I think the trim ring comes up and then everything else is the same.
3. Pull up on shift boot. Pull HARD. There are about 6 clips that will come up. The entire center piece will come off.
3a. Look at the way the cool shifter works! (MT model only)
4. Remove two screws from the U-shaped piece of trim. They are on either side, about 2/3 of the way to the dash.
5. Remove 6 clips from the side of the trim. You will see these. You can use a SMALL (read: SMALL!) hammer to knock them out softly.
6. Pull TOWARDS THE CENTER OF THE CAR (NOT the sides) on the rest of the piece. It should come off with relatively little effort.
7. Remove 2 screws from the underside, as with the 2001/2002 models.
8. Remove the dash the same as the 2001/2002 models.
9. Open beer.
10. Drink.
Old Jul 29, 2003
djuntitled's Avatar
thanks man... thats the best reply i got so far on the forums... all ive been gettin is how to's on 2001 civics.... helps a lot.... ill hit u up if i run into any problems or questions...
Old Jul 29, 2003
greggdogg's Avatar
No problem, it really is a lot easier than you think. Don't force anything, but you do have to pull hard.
Old Jul 29, 2003
blue03civic's Avatar
Pro Skater
o man haha ive been asking that question for months now and NOONE has answered it thats awesome do u have any pics of the removal cause they are always helpful and if not u think u can take some haha im a lil slow ive been trying to remove mine forever and i cant fine nething thanx a lot peace---dave
Old Jul 30, 2003
greggdogg's Avatar
I didn't take pics when I did it, but it's really not that bad. It was my first ever stereo removal.
Old Oct 6, 2003
4Saris's Avatar
4Saris is an unknown quantity at this point
Thanks, I searched my **** off and this is the only thing that distinguishes the 2003. Thanks.
Old Oct 6, 2003
4Saris's Avatar
Can anyone explain this better? Does the oval ring around the shift boot come out or the entire center console?
Old Oct 6, 2003
playaz0429's Avatar
playaz0429 is an unknown quantity at this point
you do not have to remove the shift know, just pry up (carefully) the plastic plate that is around the shift know (NOT THE SILVER PIECE, THE SQUARE BLACK ONE) and youll see screws and continue with his instructions. save time and effory by not removing the shift ****.
Old Oct 8, 2003
J_Hub's Avatar
J_Hub is an unknown quantity at this point
Thanks, all!
I've been waiting for this.
Old Oct 8, 2003
4Saris's Avatar
Yeah, I found that out the hard way that you didn't have to remove the boot. The square piece is just held in by tension clips.
Old Dec 26, 2003
Badguyelite's Avatar
Badguyelite is an unknown quantity at this point
Hey I know this sounds really bad but I have no idea how to remove the headunit on the Civic SI 2003 Has anyone done it sucessfully? I do not think the above applies.
Old Dec 26, 2003
doubledeuce2k2's Avatar
ask civicvtec1ps, he just was showing off his here...
http://www.7thgencivic.com/forums/sh...hreadid=131469
welcome to the boards, congrats on the car.
Old Apr 2, 2010
Jo K's Avatar
Jo K is an unknown quantity at this point
Re: 2003 Headunit installation (2003 ONLY not 2001 or 2002 they are not the same)
I have a Honda Civic Type S..2003 ans have had the front panel off (behind the gear shifter) and then dropped the glove box and removed the fuse box cover...I am then able to see the screws that are located either side of the stereo but am unable to fit my hands in to use any tools to remove them..any ideas folks??
Old Apr 2, 2010
hindude's Avatar
hindude will become famous soon enough
http://www.youtube.com/watch?v=ME8Uu...os=9zGHoishzk4
This is not my video but it really helped me out. I know it's for a 2004 but from what i've read about pulling the trim around the shifter off, it sounds the same. If anything, you could use it as a reference for that part. good luck.
Old Apr 2, 2010
Jo K's Avatar
I have just fitted my stereo now, a very helpful link with pictures is:
http://www.fitaudio.com/?View=entry&EntryID=19
Just the job.
Old Apr 13, 2013
freddy__15's Avatar
freddy__15 is an unknown quantity at this point
I removed my 2003 DX radio following a 2002 radio removal video :
But if you say it's not like the 2002, then follow the 2004 video :
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
izdman
May 19, 2015 03:43 PM
vino
Nov 3, 2001 11:08 PM
