my amp shuts off....
Old Jul 26, 2003
prototype's Avatar
x-factor
i have 3 12's with a rockford bd1000 and my highs are being amped by a rockford 500x. i noticed that when im listening to music loud my highs shut off but my bass stays on WTF? it shuts off for a second comes back on then shuts off again....it goes on and off like that, whats the problem with my amp? or is it the wiring? i have all stinger wires rca, power and ground wires....4 gauge wires everything is up to par all teh wires are snug so i know it cant be the wires. whats goin on here? and how do i fix the problem?
Old Jul 26, 2003
fergy016's Avatar
fergy016 is an unknown quantity at this point
i would suggest check your grouding. Does this happen only when your driving and listening to the music loud?
Old Jul 26, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Does the amp have good air circulation around it? Sounds like its going into thermal protection over and over again. Could also be a bad ground, or remote wire. Check to see if any of the lights on the amp change color when it stops playing, or if the amp is actually shutting off. It might also be wired incorrectly....you could be presenting the wrong ohm load to the amp.
Old Jul 26, 2003
prototype's Avatar
x-factor
how do i know if its the wrong ohm? i also felt the amp and its really hot........you think by adding a fan it could help? im ready to throw my system out the window, i cant listen to my radio during the day
Old Jul 26, 2003
Mystic3030's Avatar
err...to check ohms you would have to show us a wiring diagram on how you wired it....or you could use a digital multi meter.
A fan might help....are your amps in a small area with limited airflow? I would check the power/status lights on the amp when it shuts off to see if the amp is going thermal or if its just a bad remote line or somehting.
Old Jul 26, 2003
Logan3024's Avatar
Agreed, RF amps are VERY tuff to over heat unless your running 1 ohm or less. How many mids and highs are you running off the 500x?
Old Jul 27, 2003
doubledeuce2k2's Avatar
maybe tweeter protection? if you're using components? esp. with that big an amp to them, just a thought
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Solo Flow
Oct 4, 2015 07:52 AM
Mc7602
Sep 17, 2015 02:01 PM
