found another 7thgen diy online
i boogie for the raindrops
LT's right. . . if you're handy at home, you can do quite a bit after learning the basics.
If you're like me and don't have the room or the facilities to do DIY fiberglass work, then be prepared to shell-out some dough. My installer and I just talked about this earlier today. . . . to redo my whole trunk is going to cost several hundred (more like close to $2000) in custom labor. But that's for an ENTIRE trunk with multiple amps, subs, caps, fuses, neons, etc. . . with plexi.
But ANY fiberglass work is likely to cost more than you think if done in a shop.
$650 at a shop for that, ballpark.
edit: for the box alone. amp install is extra, the falsefloor rack, even if jsut cutting a hole, is extra. wiring is extra. other work is extra. 650 is my ballpark for that box built, loaded, wired to teh amp, installed in the car, and tuned. thats it.
Originally posted by 18secQuaterMile
where can one get custom fiberglass stuff made? whats a ballpark $$$ amount you might pay?
Originally posted by GreenNVicious
Do it yourself at home, that aint worth spending $$ on. We did my audio setup at tech day.
i can help anyone out in person on the norcal/socal meet with fiberglass, if your gonna be taking the drive in august.....
but usually fiberglass is a 2 day process, but regardless, i can fish out some touchy-feelies, if you want some show and tell...
