Where can i find some of these?
Old Jul 18, 2003
CallMeAdam's Avatar
CallMeAdam is an unknown quantity at this point
Or what are they called F-Plug adaptors or something?
Old Jul 18, 2003
WhiteRabbit's Avatar
they are called female RCA plugs, you get get them raw at radioshack
Old Jul 18, 2003
CallMeAdam's Avatar
Those appear to be locked down... It looks like the are threaded in the middle. don't they have another female end on the other side? (beneath the console there)
Old Jul 20, 2003
i dont think so, usually its not a barrel connector, but jsut an open head.
might be a barrel plug or a full out RCA cable tho, not something I know. maybe someone else knows, or you cna ask some shops or radioshack
Old Jul 20, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
You can "Find it at the Home Depot"
Seriously, go to their wiring isles. In the same isle as the telecom and extension cords, etc. . . there should be a section for media wiring. You should be able to find sets of F-F (female to female) barrel connectors with the surrounding nuts. These are used to install into A/V plates on the walls of living rooms, bedrooms. Nice thing is, the thickness of the panel is of little concern. You simply tighten the nuts from each end until secure.
And they're small enough you can mount them almost anywhere.
Old Jul 21, 2003
CallMeAdam's Avatar
Thank you so much Yukon!!! that's exactly what i was hoping they were. Now that you mention it i think i have seen the section you are talking about! (in home depot)
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
jherna85
General 7th Gen
Jul 9, 2015 08:10 AM
trellex
Jun 30, 2015 07:13 PM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
