Replacing front speakers - windows up or down?
Old Jul 16, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Subject says it all, I'm about to crack open my panels and put my next kicker speakers in there, just wanted to know if its better to have the window up or down while doing it. Thanks.
Old Jul 16, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Its easiest to take the door panel off the window down....then to put the speaker in (if you are fishing a new wire into your door) you need to put the window up....if you are using the OEM wire, then it doesnt matter where the window is.....
Old Jul 16, 2003
dma001's Avatar
dma001 is an unknown quantity at this point
Yes, I did my front speakers with the windows down, and I was able to make sure that my Pioneers would fit before I installed them.
Old Jul 16, 2003
GreenNVicious's Avatar
Newbie
DOWN
Old Jul 16, 2003
Cypher's Avatar
Cypher is an unknown quantity at this point
make sure after you put the speakers in, to roll the windows up and down a few times to check for clearance just in case...dont want to put everything back together and find out that something is hitting the window
got2kids
May 9, 2015 06:45 PM
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
