Switch for Underglo
Old Jul 8, 2003
tamparya's Avatar
tamparya is an unknown quantity at this point
Switch for Underglo
i hooked up my under glow and the switch is inside the car and i have it wired so it goes next to the cigarette lighter , but the switch doesnt fill up the whole space so its doesnt work i cant find anything to fill in the blank switch space so the switch is useable. Anyone have any ideas?
Old Jul 8, 2003
kalipnoi's Avatar
kalipnoi can only hope to improve
you're pretty much screwed. but you can go to a car junkyard and see if they have any of your model car (i assume 01+ civic) and take out the lower dash part that you need and buy it. or better yet i saw on ebay today that they have them, i think i have the thing bookmarked. click here just check that out. if thats not the color you need he has a biege one also. just check his OTHER ITEMS. hope that could help you.
Old Jul 9, 2003
WhiteRabbit's Avatar
if i understand right its the piece that pops out that your talkign about, right? couldnt you buy an OEM foglight switch and hack it to turn on yrou underbody neons? that fill teh whole space, not to mention look OEM....
Old Jul 9, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
i used that spot and roto-zipped it out and put a switch in there.
Old Jul 9, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
Two words...HOT GLUE. It won't look professional, but hey, it works. It has to work, hot glue is like liquid duct tape.
Old Jul 9, 2003
spat's Avatar
spat should not be trustedspat should not be trustedspat should not be trusted
take a peice of aluminim and drill out a hole in it get these switched that fit.... ahh hell give me a day and i'll take pics and post what i did... it looks amazing
Old Jul 9, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
If I get you correctly, you popped out one of the little rectangles where the OEM fog switch goes and are trying to put it there. If thats the case, position the switch the way you want it, and use duct tape on the back or something for a backing and to hold it in, then fill the gaps in the front with bondo, then you can use a small peice of sand paper and some model paint to finish it off.
The other option is what WhiteRabbit suggested, and hack the OEM fog switch to work.
Old Jul 9, 2003
tamparya's Avatar
Hey thats exactly what i did i got a piece of aluminum to fill the hole then i made a hole in the aluminum to fit the switch it doesnt exactly look amazing but its looks pretty good
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Klame9420
Sep 7, 2015 10:03 PM
junkyardguy
Sep 2, 2015 06:07 PM
