custom trunk sub box
Old Jul 2, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
I want to build a trunk box for my subs like derek's. I only want to do the middle blue part around the subs not the amp, cap, wires. What materials and tools do i need for this and how how do i do it? About how much will the materials cost? I have read the diy, but how do u cut two perfect 11" holes?
Old Jul 2, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
DIY protractor.
Actually, just make a quick device out of wood or something. Take a thin board, and measure 5.5 inches apart. Drill a small hole at each point.
Place a sharp object, like a thin screwdriver through one hole, and hold it tight to anchor it. Place a pencil through the other hole and start protracting! (Draw circle using board and pencil.)
Old Jul 2, 2003
chriscivic's Avatar
okay i get that now but what do i use to cut it? jigsaw, sawzall? ALso how do i do it like derek's?
Old Jul 2, 2003
Yukonart's Avatar
Jigsaw, baby. . . . just take it slow and steady once the lines are drawn. Nice thing is. . . if you think you're not going to cut it smooth, favor the inside of the circle. . . you can always shave more off once you've got the big center of it out.
Old Jul 2, 2003
chriscivic's Avatar
What is the material derek used dor the center piece his subs are mounted in? how do u build a box out of it?
Old Jul 2, 2003
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
I think he used some really thick plexy for that part....with some neons below. Just my thought. I am guessing he built a box and then used the plexy for the top. possible a fiberglass job, and then sealing the plexy to the box.....then inserting the subs into the plexy. May be wrong but thats what it looks like.
Old Jul 2, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
mdf is the main piece i believe... that could be either thick white plexi or a thick lexan... i made a trunk floor and had a clear window, mine however is an amp enclosure... i will probably be buying a digi cam tomorrow so i can take some pics of it... also, use a clear adhesive and per-drilled holes and screws to attach it from the back... i cut mine with a roto zip, it worked great... you can also use a jig saw, or a sawzall, anything that will allow you to make a curved cut... be warned though that getting the entire trunk floor in with out having to piece it requires a lot of effort and imagination to manuver it in there... this could become a labor intensive project... i believe it took me around 6 or so working hours to cut mine and attach the plexi and all that good stuff, but not all at one time, i worked on it a little bit each night for about a week and a half...
Old Jul 2, 2003
chriscivic's Avatar
Like this?
Name:	sub trunkk.jpg
Old Jul 3, 2003
chriscivic's Avatar
Old Jul 3, 2003
cdmx's Avatar
why not ask derek
pm him!
Old Jul 3, 2003
WhiteRabbit's Avatar
if i were doing it, id do it somewhat like the drawing. naturally, there woul be a hole in the trunk floor, the same shape as dereks. the plexyglass would be .75 inch thick, a big square, with the cutouts and holes drilled.
id have a plastics shop do that for mey, they will easily do any sort of work like that and more!
id either use white plexi ot clear with a heavy blue tint, plastics shops have all sorts of plexi to choose from. looks like derek has a translucent blue.
the box would either have no top, or a top with a hole cut in it, and the plexi sitting over that. youd never see the border, teh trunk floor would rest on top of that.
the trunk floor would be padded by its carpet and rest by gravity over the box. the plexi would be bolted using machine screws.
so would the subwoofers.
then add neons!
Old Jul 5, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
I just did a custom box. And what I did i put an x across it and in the center I put a screw.Mesarued 11 inch string and tied it around my pen. Then just draw a circle. it did it perfect.
sbi
Sep 2, 2015 07:44 AM
h4ldol
19
Jul 28, 2015 01:01 AM
