Video - DIY Changing front brakes - pads & Rotors
Rep Power: 0 Video - DIY Changing front brakes - pads & Rotors
Pretty simple job really. Don't need a lot of tools and a good project for someone who is a beginner. Plus it saves you a ton of money.
Tools required:
Jack + jack stands
19mm socket for the lugs
17mm socket for the caliper bracket
12mm socket for slide pins
C-Clamp
brake cleaner
brake grease
anti-seize (optional)
Impact drill with #2 philips head
Drill with 1/4" drill bit (may be needed)
Shop towels or paper towels
I personally like the Centric brand for pads and rotors you can find them here on Amazon (though rockauto may be cheaper even with shipping):
*****CAUTION - The links below are for 2008 Honda Civic EX *******
Centric Brake Rotor (Front): https://amzn.to/2LgVrxu
Centric Pads (Front): https://amzn.to/2J8k6aX
Tools required:
Jack + jack stands
C-Clamp
brake cleaner
brake grease
Last edited by goddom; 06-21-2018 at 12:09 PM. Reason: added links to parts on amazon + forgot to add c-clamp to tool list.
"Honda - tried, true & tested...!"
Re: Video - DIY Changing front brakes - pads & Rotors
Nice Video Bud.! Just did daughters front brakes on here mazda3 using wagner rotors & Pads all in all turned out to be a Nice job the brake pads shown are of the exact same brand its just there for the rear CT didnt stock any for the front wich i needed ended up calling & ordering them from partsource friday afternoon came in next following early Saturday morning for pick-up shes good for the next 2-3 years on brakes back ones were done a couple of months ago and front were done today by Yours truly DAD.
http://www.canadiantire.ca/en/pdp/wa...4200p.html#srp
http://www.canadiantire.ca/en/pdp/oe...0209p.html#srp
one thing I dissagree, you could use impact hammer instead of drilling the assembly bolts.. that way you can reuse them, and keeps the rotor straight. so less chatter when u drive. and lay of breaks...
1 Post
Rep Power: 117 Re: Video - DIY Changing front brakes - pads & Rotors
Some additional notes to help the DIYer: Direction of wrench is based on viewing the head of the bolt or nut CCW loosens & CW tightens. Check brake hose condition while doing brake job, swollen or frayed hoses need to be replaced. Note brake pad sequence and proper pin location (#12 & #13). Second hammer impact comment, after spraying with loosening fluid. Lay on your back to see alignment of 17mm bolts. Add wheel blocks and mechanics gloves to below list of tools. I put about 2 peas worth of brake grease in pins boots as well. Lubricate #14 surface where top and bottom of pads slide on this metal tab. At 8:50 in video a 30mm socket can be placed in piston recess to speed its compression with C clamp or caliper brake tool. Clean rag around resevor to catch any fluid over flow, paper towel can be used to remove excess fluid as well. At 11:00 in video this is the low brake pad squel indicator. I put a thin layer of grease between shims to minimize any potential noise. Good overview video, since I did this last, see my "06 EX Brake System Upgrade 2/17/15 post". See attached Honda illustration PDF.
