Engine Swaps Post information/questions about Engine Swaps here.
2009 Civic Si Turbo vs. Supercharger
Old Feb 17, 2011
drdoom76's Avatar
drdoom76 is an unknown quantity at this point
I'm kinda at a standstill. I know most civics are turboed.. But i've heard on the newer Si's the turbo sits on the firewall.. So...that's a problem.. The second option would be supercharger.. Anyone have an opinion on this?
Old Apr 10, 2011
Budahhead's Avatar
Budahhead is an unknown quantity at this point
Re: 2009 Civic Si Turbo vs. Supercharger
I'd buy a CT Engineering Supercharger. I like superchargers because they don't lag, they are cheaper, and I like the whine. What mods do you have right now? Make sure you let your car breath better before you go with a forced induction system. I.E. Headerback exhaust, Intake Manifold, throttle body and Cold Air Intake.
Old Sep 8, 2011
nicepeta's Avatar
J30 360whp/310wtq @ 7PSI
nicepeta is an unknown quantity at this point
Ill go with supercharger over turbo all day. its less power but it will last longer.
Old Nov 18, 2011
420Coupe's Avatar
420Coupe is an unknown quantity at this point
Turbo all the way. your going to end up wanting more from the car. I would have a bigger debate between all motor or turbo, a supercharger is not much cheaper and need to be rebuilt every ~80k a properly installed turbo will far outlast a supercharger in being needed to be rebuilt.
Old Dec 31, 2011
luv_mist's Avatar
luv_mist is an unknown quantity at this point
Any knowledge on the topic is appreciated honestly.
Old Aug 14, 2015
Dakota21601's Avatar
Dakota21601 is an unknown quantity at this point
I bought my Civic for a daily driver, not to modify, but if I were to modify......turbo....period. Granted, the lag is there, but i have been on many forums, and honestly, have focused most of my interest in V8 muscle/trucks, but the turboed cars/trucks hand it to the SC versions. The Hemi Rams on the Hemitruckclub forum would lay down 50hp more with a turbo setup over an SC.....at the wheel. There are other ways to make up for the lag and some of the turbo setups do that for you as well. I know a while back there was one made for a Cummins that had variable technology that would almost act like a twin turbo setup, cutting out the lag but give you the upper end boost as well. But I can't remember now who that was that made it.
Old Sep 3, 2015
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Turbos have definatly gotten better engineered to Last don't be surprised
if they last the life of the engine.
Old Sep 6, 2015
mac25's Avatar
Dr Krieger of Modification
both
Old Sep 6, 2015
Mad Dog Tannen's Avatar
supercharger- flatter power band
Turbo- good top end bad low end
basically how are you going to drive it?
cloudguy
Apr 28, 2015 05:02 AM
superstanko
Apr 28, 2015 04:38 AM
dubbc
Nov 7, 2001 02:24 PM
supraman
Nov 6, 2001 05:50 PM
LexBoy
Nov 5, 2001 08:00 PM
