Sponsored by:
Sponsored by: CARiD
Performance Muffler without the sound?! Does it happen??
Old May 8, 2003
miho's Avatar
miho is an unknown quantity at this point
Exclamation Performance Muffler without the sound?! Does it happen??
I just bought a 2002 ex coupe, I have modified a neon before, my previous car before someone hit me head on. The exhaust note got really annoying at high speeds. I want to put a muffler on this car, but I dont want the annoying exhaust noise. I want performance, nothing else, looks dont matter....would a rsx type s muffler or si muffler make a significant improvement in air flow???? any suggestions???
Old May 8, 2003
RedDragon333's Avatar
the Tanabe Rspec is the best catback on the market for this car. It provides the best Hp gains as well as torque gians. ITs a low deep throaty sound and comes with a silencer if you want to lessen the exhaust noise. YOu can get them for ~500-550 shipped
www.tornactive.com www.dezod.com www.first-1.com www.racingzoneautohouse.com
Old May 8, 2003
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
You get proformance by making it easier for the exhaust gases to escape like having larger diameter piping. Puting on a Muffer from a RSX or SI isnt going to help at all really. Just get a catback with a tone you like. Just check the thread in this section. I like my Greddy.
It isnt ricey. Nice and low. No angry bumbee sound. No pops when it peaks. The Evo is made more for Turbos and HP wise the Tanabe as stated is the best. Good Luck.
Old May 8, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
The HKS rear section has good gains (relatively speaking) and it isn't loud. Actually its probably the quietest aftermarket exhaust I've heard on a 7th gen... I love mine
Old May 8, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Who dyno'd with the Tanabe installed? Is this fact that they are the best?
Old May 8, 2003
The Tanabe was dynoed here in Houston at a local shop along with the other exhausts that are out for our car as well as a custom exhaust setup. So yes this is the reason its the best
Old May 8, 2003
xian's Avatar
Honda > Nissan
xian is on a distinguished road
What was the gain - crank & at the wheel?
Old May 8, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
Thermal R&D, deep sporty sound~
Old May 8, 2003
Boosted2k2's Avatar
Ahhh. I was just wondering.
Old May 8, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
i made a diy silencer for my muffler. all you need is aluminum foil and a couple of paper clips. the peeps wont even know you have a silencer. first, wrap several layers (like 20) around a coke can. mold it a lil and then put it directly in the smaller hole inside your muffler. make sure it is far enough in there so it exposes some of the tiny holes in the muffler. now jam some paper clips there sideways in the holes, the upper holes, connecting the lower holes and then the ones side to side. this is so the silencer doesnt fall off. it should look like a cross configuration: the octagon is the aluminum foil
1 and = are paper clip wires
____
/ 1 \
\ 1 /
works perfect on my muffler. hope this helps
Old May 9, 2003
miho's Avatar
I guess I have to buy a tanabe or hks, though I thought that the si or rsx muffler would have made a significant difference, seeing that they were made for cars with a higher displacement.
Old May 9, 2003
Their setups arent much different from the OEM ones we have. Not worth the trouble
Old May 9, 2003
AznSaint's Avatar
AznSaint is an unknown quantity at this point
magnaflow exhaust... not loud.. compared to hks and dc.
Old May 12, 2003
solarscar's Avatar
solarscar is an unknown quantity at this point
coke can? aluminum foil?
You have to be kidding.
Old May 23, 2003
Bryn's Avatar
Bryn is an unknown quantity at this point
You aren't serious, are you??
Why don't you just stick a potato in there?
____
/ 1 \
\ 1 /
Old May 23, 2003
Bartkat's Avatar
Car not run with tater in exhaust pipe.
Old May 23, 2003
HondaLuver's Avatar
Its a celebration bitches!
performance and civic do not mix, its like oil on water
Old May 23, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
mmmmmmmmmm u can get some good curly fries out of puttin a tato in the muffler. just get the ketchup ready when u start the car!!!
Old May 23, 2003
Bartkat's Avatar
That's good. Ketchup is on my "healty prostate" diet list.
Old May 23, 2003
taz757's Avatar
I just received my DC Sports TCS yesterday and it's going on tommorrow, first thing. My brother and I are going to go up to the Honda dealer where he works and we're gonna use the lifts and crap to do it right. I can't wait.
Also, you guys are saying that the Tanabe is the best exhaust for our car? I have a couple of questions for you:
1) Do you have any dyno sheets that can prove this claim that we can actually see?
2) Was the same car used for each exhaust or were their different cars with each exhaust on them that they dynoed? This makes a *big* difference as each car will respond differently to each mod.
3) What time of day were the dynoes run? Different times of day will make a big difference in a dyno run too as the air is less dense/more dense due to cold and heat. This will affect how the engine runs and this affect the actual dyno run.
Old May 23, 2003
salokod's Avatar
salokod is an unknown quantity at this point
tanabe is god
Old May 23, 2003
salokod's Avatar
why do all these people get so mad when we say tanabe is the best... just settle down, we aren't going to make you buy it.
Old May 23, 2003
Bartkat's Avatar
It just makes me feel soooo. .. well so..... intimidated.
Old May 23, 2003
Voiceofid's Avatar
End Bringer
i don't see how tempature change would impact that much on a frickin civic dyno
consider a change of 24 degrees cooler on the intake charge of a turbo mr2 only yield 15 more hp(after ic), what would the difference be on a civic? 1? 2? maybe 4?
Old May 23, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
skipping all the tater tot comments
and tanabe/dyno arguement
your Civic won't be as loud as your neon
becuase the displacement isn't as big.
I went from a 2.0L (probe) to a 1.7L(civic)
I wish the civic were louder.
cukaracha
Jun 8, 2015 05:41 PM
supercivic01
South
Nov 30, 2001 11:27 AM
colombianDXcivic
Nov 12, 2001 11:40 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
